Tag suggestion problem in Persian
(Pad Pors) #1
when as a user, I type “a”, it shows me all the tags that have “a” alphabet rather than showing me the tags that start with “a”.
point 1: if the number of tags are more than 10 and your desired tag starts with a common alphabet, you will see a long list.
point 2: in Persian, the suggesting system doesn’t work, and you always see all the tags as you start typing your desired tag.
