Hi,
i’ve installed the tag plugin in my site. However, when you have a long category name in the mobile tittle bar, it will overlap as we can see in this picture.
Is there any way to move the tag into a third row?
Thanks!
Hi,
Thanks!
What tag “plugin” are you talking about? Tags are part of Discourse core.
Also I see no overlap in your screenshot?
Hi, sorry I thought it was a plugin, but it’s integrated in Discourse in fact.I was confused.
By overlapping I mean that, as you can see in the picture, the second tag is not appearing in the title.
I would need to have it in a third line in the tittle, so users can actually see the tags of the topic.
thanks!
My solution would be to use shorter tags!
You can do it with a theme component, though. Search “#howto theme” or maybe CSS pro will chime in.
In header.scss, removing:
// the tag container should shrink
.topic-header-extra {
min-width: 1px; // 1px value is needed to avoid IE11 flexbox bug
will allow the tags to wrap.
If you want to try in your customizations use:
.extra-info-wrapper .topic-header-extra {
min-width: auto;
Great, it worked perfectly thanks thanks thanks!
