Tempfile is nil on defered uploads
(Rafael dos Santos Silva) #1
Hi,
When a user tries to upload a file in a post, the following errors occurs:
Job exception: no implicit conversion of nil into String
/var/www/discourse/app/controllers/uploads_controller.rb:69:in `size'
/var/www/discourse/app/controllers/uploads_controller.rb:69:in `create_upload'
/var/www/discourse/app/controllers/uploads_controller.rb:20:in `block in create'
/var/www/discourse/lib/scheduler/defer.rb:68:in `call'
/var/www/discourse/lib/scheduler/defer.rb:68:in `do_work'
/var/www/discourse/lib/scheduler/defer.rb:46:in `do_all_work'
/var/www/discourse/lib/scheduler/defer.rb:86:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:674:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:529:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:140:in `start'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'
After digging a bit, looks like that file.tempfile is nil, only on defered uploads.
Forcing it to be sync (uploads_controller line 15) makes the tempfile survive.
Any ideas?
Params[:file] attributes lost within Scheduler::Defer
(Rafael dos Santos Silva) #2
Looks like this is happening:
https://github.com/rack/rack/pull/671
Just doesn’t get why I can’t reproduce this on try.discourse.org
(Rafael dos Santos Silva) #3
Sorry to bump this, but this is really strange.
On my production server everything works smooth, and even upload worked before.
Last week a user said that an upload never complete, and the 100% gets stuck on the composer.
After some debugging I have found that:
  • synchronous uploads works just fine!
  • Until line 15 on the controller the File Object does have a normal tempfile.
  • If the upload isn’t synchronous at line 51 the object File doesn’t have a tempfile anymore. The error is the one on my first post.
  • If I force every upload to be synchronous everything works.
My research pointed to this change on Unicorn that could be the culprit, since I don’t know what keeps a tempfile alive after the request end.
Any points @sam ?
(Rafael dos Santos Silva) #4
Ok, closing topic.
The culprit is indeed the TempfileReaper. He got enabled automatically on Rack 1.6 and Unicorn 4.9.
By monkey patching the call method out, I disabled it and uploads are working again.
Ps.: Someday I’ll discover why this doesn’t happen on Meta/Try :smile:
(Sam Saffron) #5
I still don’t understand this, I can not see this temp file reaper middleware in our containers, are you doing a standard docker based install?
(Rafael dos Santos Silva) #6
When I use the rake taks to list the middlewares it isn’t listed.
But after monkey patching the middleware method to print the stacktrace on call I have found that it was indeed Tempfile Reaper the cause.
I don’t use the stardard install, but I’m still curious why this doesn’t happen on the standard install after unicorn 4.9 and Rack 1.6 are both in use.
BTW, this is a kinda a small race condition, maybe sidekiq can run the job before TempfileReaper runs.
(Louis Rossouw) #7
@Falco how did you fix this? I don’t follow what you mean?
(Rafael dos Santos Silva) #8
Is this happening with you too?
My fix (ugly hack) was this:
# add this to the end of the file /config/initializers/000-rails-master-polyfills.rb
module Rack
  class TempfileReaper
    def initialize(app)
      @app = app
    def call(env)
          status, headers, body = @app.call(env)
          [status, headers, body]
(Louis Rossouw) #9
Yes. The dockerless install here has this issue it seems:
Ok I’ve changed something somewhere else.
(Sam Saffron) #10
Hmm … how much of this is still relevant, should I close it?
(Rafael dos Santos Silva) #11
Yep, I was never able to repro this in Docker installs.
(Rafael dos Santos Silva) #12
(Sam Saffron) #13
Turns out this is a legit bug, we luckily avoided due to HTTP header voodoo on the way in, at LAST I have it fixed:
What was happening is that Rack was cleaning up tempfiles under some conditions which we do not hit in our docker install (but I did hit on local)
Had to fix it to unblock fixing another bug…
TLDR;
tempfiles = env[Rack::RACK_TEMPFILES]
env[Rack::RACK_TEMPFILES] = nil
# and after we are done
tempfiles&.each(&:close!)
