Testing badge sql query
badge
(PJH) #1
What happened to the ‘test badge query’ that used to be on the badge configuration screen?
What cool badge queries have you come up with?
(PJH) #2
Ok - ignore me - it doesn’t appear until you’ve
  • saved the badge
  • refreshed the page.
(PJH) #3
The other SQL query options also are missing until a refresh happens.
(Sam Saffron) #4
@riking is this workflow a bug.
(Kane York) #5
Yeah, it’s a pretty annoying bug when you’re trying to set up a new badge. The client isn’t setting some conditional that the server has as default true.
(Jay Pfaffman) #6
Has this gotten worse? I’ve saved and reloaded repeatedly and can’t see a ‘test badge query’ anywhere.
(And, would it have been better to start a new topic for this?)
(Kane York) #7
Yes, it has gotten worse… and I’ve fixed it now.
https://github.com/discourse/discourse/pull/3694
(Jay Pfaffman) #8
Awesome! Will this get pulled into the beta stream sometime soon?
(Sam Saffron) #9
Its merged now just tested and it works :city_sunrise:
(Felix Freiberger) #10
Getting this into beta will likely take a week or two.
(OG) #11
Is it just me or does anybody have trouble find this “Test badge SQL” feature?
When adding new badge I don’t see any field for SQL neither…
(Rafael dos Santos Silva) #12
