Text Editor issue with the code block
(LoveDiscourse) #1
If you would like to start a code block with the “>” character it turns into a blockquote block.
Code:
Try this:    > (4 spaces and 1 >)
Result:
(5an1ty) #2
Just tried it out on my install, same issue there.
(Jeff Atwood) #3
Yep, that is a bug, four spaces plus > should produce a code block. @eviltrout can you make sure that’s on your list?
(Robin Ward) #4
All fixed now, thanks for reporting it. I also submitted this upstream to markdown-js:
https://github.com/evilstreak/markdown-js/pull/133
(Jeff Atwood) #5
Looks good now. Thanks for these fixes @eviltrout, we (and markdown-js) are now MDTest 1.1 compliant!
(Jeff Atwood) #6
