The Github Linkback Plugin
official
(Robin Ward) #21
You should make sure the token has the permissions outlined in the project README. Those are the only ones we have running here on meta so it should work.
This is a long existing bug on Github where it streams in notifications but is not clear if it showed them already. It’s a side effect of them using PJAX instead of a proper front end framework :stuck_out_tongue:
(Daniela) #22
Well, my problem was that I set the permission clicking on repo:
enabling all subheadings.
This way the plugin does not work, enabling only the public_repo scope works fine :star_struck:.
I suggest a little update on the github README the make the requirement more clear (for newbies like me) :yum:
(Sam Saffron) #23
Can you submit a pr?
(Daniela) #24
Done. Adding “only” was very difficult :joy::rofl:
(Lukas Winkler) #25
Hi,
Thanks for the great plugin.
Is there a reason why GitHub issues aren’t linked back? Would it be possible to add a configuration option for this?
I think it would be quite useful to see which other users on the forum are having the same issue (and maybe more information on how to reproduce it)
(Jeff Atwood) #26
We don’t use GitHub issues and have no plans to… ever. Discourse fills that role for us.
(Florian Schmaus) #27
Would be great if the help text would mention this
So instead of
List of projects to link back from
something like
List the project to link back from in the format ‘user/repo’.
(Lukas Winkler) #28
Hi,
I just noticed another potential issue with the plugin.
I just posted a changelog with a list of all closed pull requests since the last release. And of course I forgot the bot until I have posted and it of course commented on all pull requests.
While this was my mistake (even though a setting to ignore some posts would be nice), this means that any forum user could spam the GitHub issue tracker with hundreds of posts just by posting on the forum. Maybe there should be a maximum of pull requests that can be mentioned in a single post.
(Jeff Atwood) #29
I am forever a fan of rate limits, everywhere, all the time!!
(misterdude) #30
Are there any plans to support this plugin for GitHub Organizations?
(Robin Ward) #31
I’m not sure what needs to change for that?
(misterdude) #32
OK, I see where I was confused. It seems the plugin only works for commits and pull requests. We use Discourse to track our user’s feature requests, which usually show us as issues, which is why it seemed to not be working for me.
Sorry for wasting your time.
