# Theme components missing on Foundation theme
**URL:** https://meta.discourse.org/t/theme-components-missing-on-foundation-theme/385709
**Category:** Site feedback
**Created:** [October 15, 2025, 2:46pm UTC](https://meta.discourse.org/t/theme-components-missing-on-foundation-theme/385709 "2025-10-15T14:46:55Z")
**Posts on this page:** 2
**Page:** 1
<div class="post-metadata">
### Author: ![Moin](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/moin/32/554653_2.png) [@Moin](https://meta.discourse.org/u/Moin)
#### Post date: [October 15, 2025, 2:46pm UTC](https://meta.discourse.org/t/theme-components-missing-on-foundation-theme/385709/1 "2025-10-15T14:46:55Z")
</div>
Continuing the discussion from [The Horizon theme cannot use the Tag icons component](https://meta.discourse.org/t/the-horizon-theme-cannot-use-the-tag-icons-component/385618/8):
> [@The Horizon theme does not display tags on topic lists](https://meta.discourse.org/t/the-horizon-theme-does-not-display-tags-on-topic-lists/385618/8):
> Tag Icons was not configured for Foundation.
I think some other components like placeholder forms and Discourse icons are missing too. It’s quite confusing when those are missing in a documentation topic. TOC seems to be missing too.
I didn’t check Horizon.
### Author: ![tobiaseigen](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/tobiaseigen/32/539204_2.png) [@tobiaseigen](https://meta.discourse.org/u/tobiaseigen)
#### Post date: [October 15, 2025, 5:47pm UTC](https://meta.discourse.org/t/theme-components-missing-on-foundation-theme/385709/2 "2025-10-15T17:47:05Z")
</div>
Yes, I had been suspecting that. I will take a look!
Edit: ok, I see that foundation has only seven components included while meta branded has dozens. I will check with the team to see what’s going on here and how we can keep them all in sync.
In the meantime I enabled placeholder forms, discourse icon and discotoc.
