Themes for Discourse?
(Sean) #1
Do you know if anyone has created any themes for Discourse
#4
If you just want to experiment with posting, you might be looking for the Discourse sandbox.
You also might try the search feature to find out whether themes have already been discussed.
Indented text is marked as preformatted, so you can post things like code without losing your indentation:
if(whatever){
   println("here");
You also might want to familiarize yourself with markdown (the text edit format used by Discourse). Try googling “markdown”, there are a ton of resources out there. Here there are links to two more resources: commonmark.org/help and BBCode, which Discourse also supports.
