Title bug: space before ! gets removed
(Dani Springer) #1
This is the title for a post of mine:
And, or, not Vs &&, ||,!
I tried adding a space between the comma and the !, but as soon as I save it, that space gets removed, and turns this:
And, or, not Vs &&, ||, !
To this:
Is this a bug? Or any intention behind this?
(Eli the Bearded) #2
This sounds like the normal title prettifier in effect. It goes along with enforcing the first letter to be a capital. In normal English, that’s the right thing to do.
Pretty sure you can use a regular no-break-space for this case, and I believe there is a site setting to never apply such fixes to titles.
(Dani Springer) #3
Makes sense. :slight_smile:
But perhaps, if the preceding character is not a letter, the space should be preserved.
In swift, ! means something, so it’s not just ending the sentence.
By the way, what do you mean by
(Eli the Bearded) #4
The bang means stuff in lots of programming languages. If you need that not to happen in your Discourse, then — clickety-click — uncheck the title prettify option in the admin settings.
And:
