Too many 429 errors
(ikbear) #1
Why there are so many 429 errors, just after 150 visitors. Can I close this xhr POST?
http://ikbear.qiniudn.com/429-errors.png
(Jake Shadle) #3
You are probably getting hit by the nginx rate limiting. Check out this post for details on how to either disable rate limiting, or the file you can modify to increase the default limits.
