Toolbar Icons not working
#1
Hello,
since the Update the my costum Toolbar Icons are away.
i have used this and set the Icons per CSS
.wmd-card-button:before { content: "\f15b"; } .wmd-deck-button:before { content: "\f15c"; }
know someone why this not work anymore?
many greetings
Imperator
#2
The composer has been rewritten, @cpradio worked on the spoiler button : GitHub - cpradio/discourse-plugin-spoiler-ui: Spoiler Composer Button for Discourse to help us update our plugins
#3
Following the plugin, you’ll just have to edit 2 files and keep the rest of the plugin.
If it helps, here an example that should work
import { onToolbarCreate } from 'discourse/components/d-editor';
export default
  initialize(container)
    const siteSettings = container.lookup('site-settings:main');
    if (siteSettings.spoiler_ui_enabled) {
      onToolbarCreate(toolbar => {
        toolbar.addButton({
          group: "extras",
          icon: "var-file",
          perform: e => e.applySurround('[card]', '[/card]', 'card_ui_default_text')
        toolbar.addButton({
          group: "extras",
          icon: "file-text",
          perform: e => e.applySurround('[deck]', '[/deck]', 'deck_ui_default_text')
en:
  js:
    composer:
      card_ui_button_title: "Import your card"
      card_ui_default_text: "id of the card"
      deck_ui_button_title: "Import your deck"
      deck_ui_default_text: "id of the deck"
I’ve been able to add my 10 buttons with this method
(cpradio) #4
You will also want to rename spoiler_ui_enabled in plugin.rb, config/settings.yml, and config/locales/server.en.yml, and utilize the updated name in your initializer above where it has siteSettings.spoiler_ui_enabled
Also, change the export default name property, if you have this truly separated from another plugin, otherwise, you will run into problems (the name: 'spoiler-ui').
