Tooltip for user menu is not meaningful
(c-i-p-h-e-r-1) #1
The menus in the upper right of the screen generally have meaningful tooltip. The one exception is what I refer to as the User menu:
Yes, the tooltip is technically correct, but it is not useful. Knowing that the image is a Profile Picture does not indicate what to expect when clicking on it. This tooltip should be updated to something like “User profile and options” so that it is more consistent with the other menu tooltips.
(Jeff Atwood) #2
Oh cipher1 who could you possibly be! You are a mystery wrapped in an enigma slathered in secret sauce! :wink:
Yes, I think this is actually a regression, introduced with shared code paths. That used to have the username there at minimum, probably at minimum it should say
{full name} profile
Where we use full name if filled out, otherwise username.
@techapj can you add that to your list?
(Arpit Jalan) #3
Okay, done:
(Jeff Atwood) #4
