Topic admin wrench is covered by customized header bar
(Kkzhang) #1
In most scene it is fine. But if custom header is set:
Admin icon’s totally invisible. Change z-index from 999 to higher digit solved this problem.
So i think i could be a bug.
Moderator "wrench" partially covered by site header
(Neil Lalonde) #2
I fixed it by increasing the z-index as you said. Feels like that wrench needs a new home. Floating way out on the top right corner of the viewport isn’t ideal.
(Jeff Atwood) #3
