Topic List Previews
#189
Not a stupid question at all.
If you are running in Production, it should bootstrap automatically.
If running a dev instance you can do that from the terminal of another session, yes.
(Luka Renko) #190
Yes, seems that recreate HTML helped. I tried it also on this and this, but after an hour they still did not get preview. Would just like to understand how preview creation works.
#191
Luka that’s very odd … I will take another look when I have time but was able to reproduce for very small images. In the meantime can you please try larger jpgs in place of the existing images?
(Luka Renko) #192
Yes, it looks like the problem is with smaller images like logo. 250x250px seems to be already enough for preview to pick it up. However, something is still wrong for images that do not have same weight and height - this is example of 500x333px image that does not get in preview.
#193
Luka, can you double check you have the thumbnail turned on in the TLP Category settings for that Category?
(Luka Renko) #194
I did enable only in Settings - Plugins:
topic list thumbnail - added all desktop lists
topic list set category defaults - enabled
topic list previews enabled - enabled
All others are left on default and nothing was configured on per-category level.
(Luka Renko) #196
Is it possible that this is due to the fact that topic is wiki? I have noticed another wiki topic without preview image.
#197
I personally have never tested that. I’ll try and repro when I get chance.
(Bart) #198
Since I updated TLP this week I’ve noticed a significant slowdown of my site. Tracking it down with the mini profiler, it seems to be caused by TLP - this one particular query often takes up to one full second to complete. Could this be due to the change that you made to the thumbnail custom meta this week, @angus?
(Luka Renko) #199
@merefield I think I have found the root cause of missing previews: they do not show for images that have scaling added, e.g.
![anchor|115x105,60%](upload://st8dnQ5PLu65ME8ybJI5xxIzuBP.jpeg)
I noticed this on one post that had preview before, but lost it after my edit when I fixed scaling to make the post more readable. I checked other posts and removed scaling and the preview shows immediately and is removed when scaling is added back.
#200
Luka that’s a great find, thank you and glad you have sorted it. Does anything show in your logs when scaling is added?
(Luka Renko) #201
Did not notice anything suspicious in production.log, but I am new to Discourse so not sure if there is any other log that I should check.
#202
should show up in the browser (if at all) @ example.com/logs
(Luka Renko) #203
There is nothing there.
#204
Hi,
Is there a sane way to modify the tile view layout? (apart from the jquery way)
I’m still fairly new to the customization, usually, from my understanding, you would overwrite topic-list-item template, but because it’s overwritten by the plugin, you can’t use it (it would seem).
I’m just looking for a clean way to do that.
#205
By CSS or fork the plugin.
What was your aim?
#206
Moving around HTML elements when CSS is not enough or too tricky. Like, for example, moving some of the metadata such as the actions or category at the top. I believe there is no easy way to achieve that only in CSS (unless there are no nested elements, and I think you could play with the grid system).
It would have been be easier if you could place the elements like you want, avoiding dirty stuffs.
Also, more generally I wanted to know if customization is still possible in this context.
Thanks for the answer.
On a unrelated side node, it reminds me that because this plugin overwrites this view, it looks like it has side-effects on the Topic Rating plugin: the ratings HTML doesn’t appear in the tile view. I’ve actually posted on the concerned topic, but I’m not sure whether it should be asked here. Is there something which can be done to fix this issue?
#207
I’m literally right now mid-coding a PR to improve the layout for tiles (Category is going up under the title and there will be better handling for the user list display). It got delayed slightly due to competing priorities but back on it.
Yes this requires changes to the plugin unfortunately because nested CSS grids need nested elements - you can’t just do that with CSS (which is a shame). I’d suggest you wait for the improved layout and decide if you like it. Actions is going bottom right (because this is where your thumb is usually (sorry left handers!)).
No, tiles was never designed/tested to support the ratings plugin but support could be added at some stage.
#208
I see. I’m looking forward to the improvements then!
About the rating, that would be welcomed if it was supported.
Do you know some possible workaround to show them? I’m still new to the API stuff, but maybe it would be possible to access topic data (not sure how, I think the topic list is saved into the session at some point, maybe that), retrieving the current rating and inserting the rating HTML?
#209
I’m just guessing but I think there must be a hook of some kind that is missing. I’ve not studied the ratings plugin. Angus is better to comment.
You can always help priority by sponsoring the work (or you could have a crack at it yourself and submit a PR :slight_smile: )
