# Build failed
**URL:** https://meta.discourse.org/t/topic/411795
**Category:** Support
**Created:** [September 7, 2026, 7:18am UTC](https://meta.discourse.org/t/topic/411795 "2026-09-07T07:18:05Z")
**Posts on this page:** 4
**Page:** 1
<div class="post-metadata">
### Author: ![singi2016cn](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/singi2016cn/32/532755_2.png) [@singi2016cn](https://meta.discourse.org/u/singi2016cn)
#### Post date: [September 7, 2026, 7:18am UTC](https://meta.discourse.org/t/topic/411795/1 "2026-09-07T07:18:05Z")
</div>
I encountered the following error during the build:
```plaintext
[log] <DIR>/assets/js/chunk-kzds8qh6.digested.js chunk │ size: 297.19 kB
[log] <DIR>/assets/js/chunk-b1q66eup.digested.js chunk │ size: 358.64 kB
[log] <DIR>/assets/js/jspreadsheet-c0a3yubd.digested.js chunk │ size: 475.17 kB
[log] <DIR>/assets/js/codemirror-editor-fo821emj.digested.js chunk │ size: 498.87 kB
[log] <DIR>/assets/js/chunk-enbilv94.digested.js chunk │ size: 506.45 kB
[log] <DIR>/assets/js/jsoneditor-dmbb2ak0.digested.js chunk │ size: 530.72 kB
[log] <DIR>/assets/js/ace-editor-bundle-bd9fwf91.digested.js chunk │ size: 612.67 kB
[log] <DIR>/assets/js/full-calendar-bundle-fr7dwh7s.digested.js chunk │ size: 992.27 kB
[log] <DIR>/assets/js/admin-c45bp8xv.digested.js chunk │ size: 1,343.19 kB
[log] <DIR>/assets/js/faker-o7ara9hb.digested.js chunk │ size: 2,321.90 kB
[log] <DIR>/assets/js/discourse-kovviugm.digested.js chunk │ size: 3,577.22 kB
[log]
[success] rolldown v1.1.2 Finished in 18.40 s
/var/www/discourse/plugins/discourse-ai/lib/tasks/create_topics.rake:51: warning: already initialized constant TopicGenerator::FIRST_POST_RESPONSE_FORMAT
/var/www/discourse/plugins/discourse-ai/lib/tasks/create_topics.rake:51: warning: previous definition of FIRST_POST_RESPONSE_FORMAT was here
/var/www/discourse/plugins/discourse-ai/lib/tasks/create_topics.rake:69: warning: already initialized constant TopicGenerator::REPLIES_RESPONSE_FORMAT
/var/www/discourse/plugins/discourse-ai/lib/tasks/create_topics.rake:69: warning: previous definition of REPLIES_RESPONSE_FORMAT was here
Compiling 49 plugins...
Finished initial compilation of plugins in 33.75s
rake aborted!
Don't know how to build task 'assets:precompile:pretty_text' (See the list of available tasks with `rake --tasks`)
Did you mean? assets:precompile
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/rake-13.4.2/exe/rake:27:in '<top (required)>'
/usr/local/bin/bundle:25:in 'Kernel#load'
/usr/local/bin/bundle:25:in '<main>'
I, [2026-09-07T07:06:45.573543 #1] INFO -- : Terminating async processes
I, [2026-09-07T07:06:45.619547 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/18/bin/postgres -D /etc/postgresql/18/main pid: 45
I, [2026-09-07T07:06:45.621006 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 128
128:signal-handler (1788764805) Received SIGTERM scheduling shutdown...
2026-09-07 07:06:45.621 UTC [45] LOG: received fast shutdown request
2026-09-07 07:06:45.628 UTC [45] LOG: aborting any active transactions
128:M 07 Sep 2026 07:06:45.638 * User requested shutdown...
128:M 07 Sep 2026 07:06:45.639 * Saving the final RDB snapshot before exiting.
2026-09-07 07:06:45.661 UTC [45] LOG: background worker "logical replication launcher" (PID 62) exited with exit code 1
2026-09-07 07:06:45.679 UTC [57] LOG: shutting down
2026-09-07 07:06:45.685 UTC [57] LOG: checkpoint starting: shutdown immediate
128:M 07 Sep 2026 07:06:46.044 * DB saved on disk
128:M 07 Sep 2026 07:06:46.044 # Redis is now ready to exit, bye bye...
2026-09-07 07:06:46.063 UTC [57] LOG: checkpoint complete: wrote 56 buffers (0.1%), wrote 3 SLRU buffers; 0 WAL file(s) added, 0 removed, 0 recycled; write=0.357 s, sync=0.004 s, total=0.381 s; sync files=22, longest=0.002 s, average=0.001 s; distance=321 kB, estimate=321 kB; lsn=1/18C7340, redo lsn=1/18C7340
2026-09-07 07:06:46.118 UTC [45] LOG: database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  if [[$(git symbolic-ref --short HEAD) == release/2026.7]] ; then
      SKIP_DB_AND_REDIS=1 bundle exec rake assets:precompile:build assets:precompile:pretty_text
  else
  fi
' failed with return #<Process::Status: pid 729 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.4.0/gems/pups-1.4.0/lib/pups/exec_command.rb:138:in 'Pups::ExecCommand#spawn'
exec failed with the params {"cd" => "$home", "tag" => "build", "hook" => "assets_precompile_build", "cmd" => ["sudo -H -E -u discourse bash -c '\n if [[$(git symbolic-ref --short HEAD) == $version]] ; then\n SKIP_DB_AND_REDIS=1 bundle exec rake assets:precompile:build assets:precompile:pretty_text\n else\n SKIP_DB_AND_REDIS=1 bundle exec rake assets:precompile:build\n fi\n'"]}
**FAILED TO BOOTSTRAP** please scroll up and look for earlier error messages, there may be more than one.
582d39a0c9c78bab114c5abfda91bc8ea8322552034c78ee50f92c504d58323c
My `app.yml` is
```plaintext
templates:
  - templates/postgres.template.yml
  - templates/redis.template.yml
  - templates/web.template.yml
  - templates/web.ratelimited.template.yml
  - templates/web.ssl.template.yml
  - templates/web.letsencrypt.ssl.template.yml
  - templates/web.china.template.yml
expose:
  - 80:80
  - 443:443
params:
  db_default_text_search_config: pg_catalog.english
  db_shared_buffers: 768MB
  version: release/2026.7
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 4
  DISCOURSE_DOWNLOAD_PRE_BUILT_ASSETS: 0
#### Post date: [September 7, 2026, 7:22am UTC](https://meta.discourse.org/t/topic/411795/2 "2026-09-07T07:22:07Z")
</div>
It looks like the update missed something. Below are the results of an AI analysis:
## Problem Description
The issue is a version mismatch between the **Docker base image** and the **`release/2026.7` branch code** :
### What Happened
During the bootstrap process, the build script embedded in the Docker base image `discourse/base:2.0.20260109-0020` executes the following command:
```plaintext
    # This task does not exist!
fi
### Why It Failed
| Location | Status |
| `discourse/base` image | The new image requires the `assets:precompile:pretty_text` task to be run |
| `release/2026.7` branch | **Does not have** this rake task (not defined in `lib/tasks/assets.rake`) |
| `main` / `release/2026.8` | **Has** this task (from commit `cfed6b85b6c`, Rolldown PrettyText migration) |
In short: **The image is new, but the code branch is old**. The image requires executing a task that does not yet exist in the older branch.
### Fix Options
| Option | Action |
| **Recommended: Upgrade to `release/2026.8`** | Modify the `version: tests-passed` or branch name in the container configuration file; this branch includes the task |
| Downgrade the base image | Use an older version of the `discourse/base` image that does not include the `pretty_text` build step |
| Manually add an empty task | Add an empty `assets:precompile:pretty_text` task in `lib/tasks/assets.rake` (temporary workaround) |
### Author: ![merefield](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/merefield/32/176214_2.png) [@merefield](https://meta.discourse.org/u/merefield)
#### Post date: [September 7, 2026, 8:24am UTC](https://meta.discourse.org/t/topic/411795/3 "2026-09-07T08:24:21Z")
</div>
That task exists on main/latest and 2026.8.0:
> <https://github.com/discourse/discourse/blob/a0407f8f6e3bf47b4aa4f9e57fbea015a18fdc80/lib/tasks/assets.rake#L164>
Curious!
Can you switch to 2026.8.x?
### Author: ![Moin](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/moin/32/554653_2.png) [@Moin](https://meta.discourse.org/u/Moin)
#### Post date: [September 7, 2026, 8:29am UTC](https://meta.discourse.org/t/topic/411795/4 "2026-09-07T08:29:50Z")
</div>
> [@What to know before upgrading from v3.4.0 to v2026.7.2](https://meta.discourse.org/t/what-to-know-before-upgrading-from-v3-4-0-to-v2026-7-2/411291/5):
> Hey @corywright sorry about that - Current ESR doesn’t have the job, patch in flight [here](https://github.com/discourse/discourse_docker/pull/1126). We’ll get it fixed up soon, and I’ll ensure the ESR target is added as a smoke test target to prevent future regressions.
