Topics list scrolling buggy after upgrade
#1
Hi,
i recently upgraded to the newest version but now the topic list scrolling is very slow.
Once i scroll down in the topic list it gets stuck for almost a minute.
Forum is located on: https://wmforum.geek.hr
I dont know if its hosting related or a bug with the script.
I’ve also found some errors in the log file:
Any ideas?
(Sam Saffron) #2
Try safe mode
Does issue go away?
#3
Hi, yes in safe mode it works fine.
Disabling only plugins does not nothing, so its something with the site_customization.
However i removed all custom made CSS and the problem is still there. Not sure what else should i try removing.
(Sam Saffron) #4
This can be due to custom html you have as well, look at all the tabs in your site customization.
