Trac plugin for SSO
(Alexandru Chirila) #1
If you want to use Trac as Single Sign On point for Discourse we’ve developed a plugin that allows you to do this. It’s easily installable and configurable.
After installation simply add the details to you configuration file. For example:
[sso]
sso_secret = thisisatestsecret
sso_redirect = https://my.discourse.example.com/session/sso_login
And grant the SSO_LOGIN permission to any user you deem fit :smile:
For more information, sources and downloads see:
GitHub - SpamExperts/trac-sso: Trac Single Sign On plugin
(Kane York) #2
@sam I moved this back to the SSO category, as this code goes on the Trac system, not Discourse.
