Transfer to anonymous mode failed
#1
  1. I’ve already enabled anonymous mode in setting menu.
  2. I’ve already set trust level with “1”.
I clicked the anonymous mode icon from the drop-down menu, but had no response. Is there something wrong of the settings? I tried both admin and normal account.
(anonymous13) #2
Hmmm … is anonymous mode working?
(Sam Saffron) #3
anonynmous mode appears to be working here… can you repro the issue here?
#4
Anonymous mode works fine here, I think it’s my site’s problem but don’t know what’s going wrong…
Actually I‘m using IP:PORT to locally access the site, will that be a problem?
(Jeff Atwood) #5
Discourse does not support being on non standard ports, you will need to proxy to a standard port.
