Transifex enforces parenthesis in translations - can it be switched off?
(Anton) #1
In some cases, the translation should not contain parenthesis.
For example:
Average time (hours)
In Russian, however, units of measurement must be specified after comma:
Среднее время, часов
(hours translates to the word marked in bold)
Transifex does not let me Review the translation:
Can this enforcement be switched off, or is it the way Transifex works?
p.s. Translation key: reports.time_to_first_response.yaxis
(Gerhard Schlager) #2
Unless they changed this recently, the following will work: Select a different item in the list and then select the problematic one again. Reviewing should now work.
(Anton) #3
This does not work anymore, unfortunately :frowning:
(Gerhard Schlager) #4
Try again. Works fine for me.
Another trick that still works: Review it first and change the translation afterwards. :wink:
