Translation missing for pl_PL.voting.votes.few?
(Tomek) #1
I have a string missing (pl_PL.voting.votes.few) and I cannot manually add a translation for it, how can I fix it?
(Evgeny) #2
Add the following line to your language file
(Tomek) #3
I use polish language, there is no translation for it so I guess I should add this to en then?
(Tomek) #4
OK, problem solved.
How can you add client.pl.yml to the project, I have just finished the translation?
(Evgeny) #5
@TomekB
I think that you need to add it to the original project, here:
(Tomek) #6
I have done just that :slight_smile:
