Clickable telephone numbers in replies?
I would like the phone numbers added to the topic to be clickable and triggers the phone to call.
I inserted an HTML simple code however, on iphone broswer it does not work.
Appreciate your help
If a call to action button is a solution, that would be great.
See
it should work by adding a bit of CSS
Do tel URIs not work? callme
Hm I wouldn’t expect SIP URIs to work, but I’m surprised a basic tel URI with a valid e.164 number is ignored.
I did the same thing by adding the call <a href="tel:+1-555-438-3732">1-555-IETF-RFC</a> and didn’t work.
The thing is when you try to click on the number the topic itself turns into light gray background if you know what i mean. Something like iframe effect or so
But did you also add “tel” in the site setting allowed href schemes?
No effect :frowning:
See
You’re awesome :wink:
