Triggering Actions from Connector from Plugin
#1
Hello guys,
I am writing a small plugin.
The server functionality is in place, I can access it via API without problems.
Now I also have a connector in place using an outlet - this is rendering fine.
The problem I have now is, that I want to trigger an actin from a button in the template file. Where would I need to place the corresponding action?
Tried different things, like extending the Routes like so:
export default Discourse.Route.extend({
  actions: {
    myAction: function() {
      console.log("Do something");
Maybe someone could point me in the right direction.
Greetz,
Chris
(cpradio) #2
The outlet you are using will ultimately help drive what component/model you need to reopen and add an action to.
This plugin is no longer needed, but I’m keeping it around as an example, because it took me a while to figure it out too.
In short, you want to setup an initializer that reopens the compoent you want to extend with a new action.
#3
Thank you, this was the missing link.
The outlet I am using does not have a matching component, so I looked one level higher and just reopened and extended an available controller.
Since actions bubble up, I could also reopen the matching Router and add it there (which I tried, just to make sure that I grasped it ;-)).
You helped my understanding the whole stack a little bit more - Thank you.
Greetz,
Chris
