Trouble restoring a Discourse backup from 1.6
(Dante) #1
How do I download Discourse 1.6
Because now is the Discourses 1.6.1
I can not restore a backup
PLS
(Rafael dos Santos Silva) #2
First take a deep breath.
Now, be happy. You can restore a 1.6.0 backup in a 1.6.1 Discourse just as fine.
(Dante) #3
tx so much :sweat_smile:
(Dante) #4
but sry why restore failed:sweat_smile::sweat_smile:
(Jay Pfaffman) #5
It is better to copy and paste the text than take a screenshot, but it looks like a disk space problem.
(Dante) #6
sry
[2016-09-14 13:29:10] [STARTED]
[2016-09-14 13:29:10] '862055200' has started the restore!
[2016-09-14 13:29:10] Marking restore as running...
[2016-09-14 13:29:10] Making sure /var/www/discourse/tmp/restores/default/2016-09-14-132910 exists...
[2016-09-14 13:29:10] Copying archive to tmp directory...
[2016-09-14 13:29:10] Unzipping archive, this may take a while...
[2016-09-14 13:29:12] EXCEPTION: Failed to unzip archive.
gzip: /var/www/discourse/tmp/restores/default/2016-09-14-132910/cuneo360-2016-08-03-091153 (1).tar.gz: unexpected end of file
[2016-09-14 13:29:12] /var/www/discourse/lib/backup_restore/utils.rb:8:in `execute_command'
/var/www/discourse/lib/backup_restore/restorer.rb:188:in `block in unzip_archive'
/usr/local/lib/ruby/2.3.0/fileutils.rb:128:in `chdir'
/usr/local/lib/ruby/2.3.0/fileutils.rb:128:in `cd'
/var/www/discourse/lib/backup_restore/restorer.rb:187:in `unzip_archive'
/var/www/discourse/lib/backup_restore/restorer.rb:36:in `run'
/var/www/discourse/lib/backup_restore/backup_restore.rb:163:in `block in start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:160:in `fork'
/var/www/discourse/lib/backup_restore/backup_restore.rb:160:in `start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:19:in `restore!'
/var/www/discourse/app/controllers/admin/backups_controller.rb:81:in `restore'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/abstract_controller/base.rb:198:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/callbacks.rb:117:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/callbacks.rb:505:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionview-4.2.7/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/mini_profiler/profiling_methods.rb:102:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/routing/mapper.rb:49:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/routing/route_set.rb:817:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.3.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:129:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.7/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/logster-1.2.5/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:13:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.7/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.1/lib/mini_profiler/profiler.rb:278:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.1/lib/message_bus/rack/middleware.rb:62:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.7/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/lib/unicorn/http_server.rb:562:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/lib/unicorn/http_server.rb:658:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/lib/unicorn/http_server.rb:508:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/lib/unicorn/http_server.rb:132:in `start'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.1.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:23:in `<main>'
[2016-09-14 13:29:12] Trying to rollback...
[2016-09-14 13:29:12] There was no need to rollback
[2016-09-14 13:29:12] Notifying '862055200' of the end of the restore...
(Jay Pfaffman) #7
Unexpected end of file looks like the whole backup didn’t get uploaded.
(Dante) #8
Thank you, I try to upload
(Dante) #9
Once again …
[2016-09-14 14:06:42] '862055200' has started the restore!
[2016-09-14 14:06:42] Marking restore as running...
[2016-09-14 14:06:42] Making sure /var/www/discourse/tmp/restores/default/2016-09-14-140642 exists...
[2016-09-14 14:06:42] Copying archive to tmp directory...
[2016-09-14 14:06:42] Unzipping archive, this may take a while...
[2016-09-14 14:06:44] EXCEPTION: Failed to unzip archive.
gzip: /var/www/discourse/tmp/restores/default/2016-09-14-140642/cuneo360-2016-08-03-091153 (1).tar.gz: unexpected end of file
[2016-09-14 14:06:44] /var/www/discourse/lib/backup_restore/utils.rb:8:in `execute_command'
[2016-09-14 14:06:44] Trying to rollback...
[2016-09-14 14:06:44] There was no need to rollback
[2016-09-14 14:06:44] Notifying '862055200' of the end of the restore...
[2016-09-14 14:06:47] Cleaning stuff up...
[2016-09-14 14:06:47] Removing tmp '/var/www/discourse/tmp/restores/default/2016-09-14-140642' directory...
[2016-09-14 14:06:47] Unpausing sidekiq...
[2016-09-14 14:06:47] Marking restore as finished...
[2016-09-14 14:06:47] Finished!
(Jay Pfaffman) #10
Perhaps the whole backup didn’t get downloaded?
(Dante) #11
thx Maybe,
but this is my only 1.6 backup, a backup thing 1.5.x, how should I do…?
(Jay Pfaffman) #12
You can tdo y to uncompressed the file on my out computer to confirm that it’s bad.
How to restore to 1.5 is totally possible ,but not something I can explain from my tablet before breakfast. :smile:
(Rafael dos Santos Silva) #13
The team did some work on optimizing backups a while ago. During this period we had some problems with incompatible backups. I think that what’s happening with you.
I would try to restore this backup on a up to date version (1. 7.0.beta4) because that may work.
(Dante) #14
thx
This is backed up on August 3 , need my backup right?
(Alan Tan) #15
I noticed that the file does not have the right extensions. Did you rename or run any operations on the file before uploading?
(Dante) #16
no
(Mittineague) #17
The “(1)” suggests that you are trying to import a copy of the backup file rather than the original backup file.
If this is the case, are both files the exact same size?
Can you try importing the original backup file?
My thinking is the file may have become corrupt during the copy process.
Hmmm. Or maybe the Discourse backup code chokes on parentheses in the file name?
(Jay Pfaffman) #18
Are you saying that after 1.7.0.beta4 you can (or probably can) restore any backup that’s older than the current version? I’m tweaking import HOWTOs and I got burned by importing to a newer version than the hosting provider was using. Do we think that if version running the place that you’re restoring to has a newer version than where the backup was made you’re safe?
(Richard - DiscourseHosting.com) #19
You can do that for a long time. Discourse runs db:migrate after the backup has been imported to make it up to date.
It probably just has been downloaded twice. Just remove the (1) part and the space. I think the space is causing the issue since there are no quotes around the file name in the command line.
(Jay Pfaffman) #20
Hmm. A client had trouble importing a 1.6.1 database into his 1.7.x instance recently and I thought it was a Discourse version problem. Perhaps it was a PG version problem.
