Trouble with Top Traffic Sources Data
#1
I have Google Analytics setup via Admin > Settings > Basic Setup. When I visit GA there is an alert that says my tracking code is missing. This appears to be an old message, so it may not longer be relevant.
When I visit my ADMIN area in Discourse I see that Github is often a top referrer. It’s my understanding that while not accessible via Discourse, that referral data should be easy to get from GA. I’m checking traffic Channels, Source/Medium, Referrals, but nothing shows any reference to GitHub anywhere. Am I looking in the wrong place or does this mean my GA setup within Discourse is not right?
(Rafael dos Santos Silva) #2
Google Analytics is a JavaScript snippet. So if you have something like an image in your forum hotlinked on GitHub, it will show as a top traffic source on discourse but nothing in Google Analytics.
You can check this theory easily parsing the nginx logs on the shared folder.
#3
For the benefit of those who are not as technical as I am…how would one easily parse the nginx logs on the shared folder?
:blush:
(Rafael dos Santos Silva) #5
Looks like we can do this using a simple Data Explorer query:
SELECT
  d.name,
  r.path,
  COUNT(*) as occurrences
FROM
  incoming_links AS l
INNER JOIN
  incoming_referers AS r ON r.id = l.incoming_referer_id
INNER JOIN
  incoming_domains AS d ON d.id = r.incoming_domain_id
WHERE
  l.created_at > (CURRENT_DATE - 30)
GROUP BY
  1, 2
ORDER BY
  3 DESC
