Troubleshooting Discourse crash?
(Philip Colmer) #1
One of our Discourse platforms crashed last night. A restart got it working again but I’d like to try and better understand what caused the problem, particularly if that helps the code improve.
Unfortunately, I can’t see anything in the logs that hints at Discourse actually crashing. The logs continue to show messages even after a site admin had reported that Discourse was down and all we were getting was 500 errors.
There are lots of warnings like this:
failed to deliver message, skipping #<struct MessageBus::Message global_id=321617, message_id=3795, channel="/site_settings", data={"process"=>"d9ded469-6c45-4cca-9dcf-3e18b949f182"}>
ex: no implicit conversion of nil into String backtrace: ["/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/connection/hiredis.rb:19:in `connect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/connection/hiredis.rb:19:in `connect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:336:in `establish_connection'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:101:in `block in connect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:293:in `with_reconnect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:100:in `connect'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:364:in `ensure_connected'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:221:in `block in process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:306:in `logging'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:220:in `process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:120:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:494:in `block in del'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in `block in synchronize'", "/usr/local/lib/ruby/2.3.0/monitor.rb:214:in `mon_synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in `synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:493:in `del'", "/var/www/discourse/lib/discourse_redis.rb:192:in `block in del'", "/var/www/discourse/lib/discourse_redis.rb:146:in `ignore_readonly'", "/var/www/discourse/lib/discourse_redis.rb:190:in `del'", "/var/www/discourse/lib/cache.rb:53:in `delete_entry'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/cache.rb:402:in `block in delete'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/cache.rb:547:in `block in instrument'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/notifications.rb:166:in `instrument'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/cache.rb:547:in `instrument'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/cache.rb:401:in `delete'", "/var/www/discourse/lib/site_setting_extension.rb:379:in `clear_cache!'", "/var/www/discourse/lib/site_setting_extension.rb:235:in `block in refresh!'", "/var/www/discourse/lib/site_setting_extension.rb:216:in `synchronize'", "/var/www/discourse/lib/site_setting_extension.rb:216:in `refresh!'", "/var/www/discourse/lib/site_setting_extension.rb:254:in `process_message'", "/var/www/discourse/lib/site_setting_extension.rb:242:in `block in ensure_listen_for_changes'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:535:in `block (2 levels) in global_subscribe_thread'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:549:in `each'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:549:in `block in multi_each'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:548:in `each'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:548:in `multi_each'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:533:in `block in global_subscribe_thread'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/backends/redis.rb:331:in `block (2 levels) in global_subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/subscribe.rb:45:in `block in subscription'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:141:in `block (3 levels) in call_loop'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:135:in `loop'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:135:in `block (2 levels) in call_loop'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:231:in `block (2 levels) in process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:367:in `ensure_connected'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:221:in `block in process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:306:in `logging'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:220:in `process'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:134:in `block in call_loop'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:280:in `with_socket_timeout'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/client.rb:133:in `call_loop'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/subscribe.rb:43:in `subscription'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis/subscribe.rb:12:in `subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2760:in `_subscription'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2138:in `block in subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in `block in synchronize'", "/usr/local/lib/ruby/2.3.0/monitor.rb:214:in `mon_synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:58:in `synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/redis-3.3.1/lib/redis.rb:2137:in `subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/backends/redis.rb:304:in `global_subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:513:in `global_subscribe_thread'", "/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus.rb:461:in `block in new_subscriber_thread'"]
and quite a few “fatal” messages like this:
TypeError (no implicit conversion of nil into String)
Does the fact that it was still logging suggest that it wasn’t Discourse itself but, perhaps, nginx that was the cause of the failure? Where do I need to look to pin this down further?
Thanks.
Losing redis connection
