Trying to reset password without any luck
unsupported-install
(Michal Jurník) #1
Hi all!
I have a problem with sending new password to my e-mail.
I send an invitation (as admin), log in from invitation e-mail link and try to reset password. Everything works fine, UI tells me that the e-mail with a new password was send but I don’t receive anything.
I looked into activity log and there’s literally nothing. Any idea what’s going on?
Thanks for help!
(Felix Freiberger) #2
Are you using a recommended Docker-based install?
Is sidekiq running? Try visiting /sidekiq to check its health.
(Michal Jurník) #3
Thank you for reaction Felix.
Yes, there is some failures.
(Felix Freiberger) #4
Try having a look at /log to see whether there are any related log entries.
(Michal Jurník) #5
Log is perfectly clear. Unfortunately, there is nothing to see.
(Felix Freiberger) #6
In that case, I’d assume that your email is sent but has deliverability issues.
Try this:
  1. Go to http://www.mail-tester.com/
  2. Copy the email you get.
  3. Go to /admin/email and trigger a test email to the address you triggered.
  4. Click the button on Mail Tester and post the results.
(Michal Jurník) #7
Nope, It works properly. Still I am not getting any e-mails except the invitation e-mail.
Any other idea?
Thank you for any information
(Felix Freiberger) #8
Can you post the results from mail-tester.com?
Also, can you answer this question?
(Michal Jurník) #9
Actually, I install it right to the Azure through this link: Bitnami Open Source Applications for Microsoft Azure
Thank you Felix for your advise. Finally solve it.
The reason was SPF limitation of my SendGrid account. I changed the SMTP relay to my Gmail account and it works now.
(Felix Freiberger) #10
Ouch. The Bitnami install is unsupported and appears to be subtly broken judging by the support requests that surface here.
I highly recommend that you take a backup of your site, reinstall using these instructions and restore your backup to avoid issues later.
(Jay Pfaffman) #11
That’s a violation of Google’s terms of service and won’t work for long.
(Michal Jurník) #12
Thank you guys for answers.
I am a little bit angry now because of unsupported version.
Therefore It’s definitely time to consider hosted solution.
(Jay Pfaffman) #13
You can do your own self-hosted install by following these directions.
