Tuning settings for SSL?
(Stephen) #1
So we’ve recently switched our Discourse install over to use SSL and have noticed that the initial page loading time is now significantly higher.
Our install sits on a 2GB/2CPU DigitalOcean droplet, is this simply to small for reasonable performance with SSL? are there config tweaks we can make to improve matters?
(Dean Taylor) #2
SSL will slow things down, but the amount this slows the initial load can be optimised.
A simple way to visualise this is here:
Check your site with http://www.webpagetest.org/ to find the specific delays.
Also check out https://istlsfastyet.com/
