Twitch.tv embed is not working correctly
(Jacob Chapel) #1
I am not sure why this is causing problems, but when I try to embed a Twitch.tv stream (just by linking it) the url is messed up in the iframe causing it to load a page from my domain and 404.
Here is what happens:
(Jacob Chapel) #2
Note above, the iframe src link is
https://meta.discourse.org/t/twitch-tv-embed-is-not-working-correctly/http:www-cdn.jtvnw.net/swflibs/TwitchPlayer.swf?channel=goldenboyftw&playerType=facebook
(Jeff Atwood) #3
Interesting, @techapj can you have a look?
(Arpit Jalan) #4
Okay, I looked into it, and it seems like Twitch recently broke the Video URL they provide via Open Graph:
<meta content='http:www-cdn.jtvnw.net/swflibs/TwitchPlayer.swf?channel=leko92&playerType=facebook' property='og:video'>
<meta content='https:www-cdn.jtvnw.net/swflibs/TwitchPlayer.swf?channel=leko92&playerType=facebook' property='og:video:secure_url'>
Notice http:www-cdn.jtvnw.net, instead it should be http://www-cdn.jtvnw.net.
I’ll try to communicate this to Twitch Developers.
#5
Don’t you love it when it’s not your fault!
:slight_smile:
(Jacob Chapel) #6
Odd, when I went to check myself, it was properly formatted.
Okay, so when going to http://www.twitch.tv/leko92 the video urls are formatted properly.
When going to http://www.twitch.tv/leko92/embed it shows the above.
What is causing it to use the embed url, I don’t see anything in onebox specific to Twitch.
(Arpit Jalan) #7
Onebox uses Open Graph protocol to embed Twitch video stream. When you will view page source for http://www.twitch.tv/leko92, you will see:
<meta content='video.other' property='og:type'>
<meta content='application/x-shockwave-flash' property='og:video:type'>
Onebox will detect that it has to embed video, by seeing property og:type which has content video:other. Then it will look for video url in property og:video which has content http:www-cdn.jtvnw.net/swflibs/TwitchPlayer.swf?channel=leko92&playerType=facebook.
Now since the video url is broken, the Onebox embed is creating trouble.
Hope, this makes clear how Twitch embed works. :slight_smile:
(Jacob Chapel) #8
I understand how it works. My point is if you go to the base user page, without /embed, the og:video links are correct and have the // as they should.
This is definitely a Twitch.tv issue, but its not always showing the incorrect meta tags.
(Arpit Jalan) #9
Weird, when I view source for base user page (without /embed), it has broken og:video links:
(Jeff Atwood) #10
Did Twitch fix this?
(Arpit Jalan) #11
Not yet, just created a new issue for this:
https://github.com/justintv/Twitch-API/issues/259?1
(Arpit Jalan) #12
Twitch.tv fixed the issue! :smile:
http://try.discourse.org/t/twitch-tv-onebox/323
(Arpit Jalan) #13
