TypeError in Chrome 32 (dev) on frontpage
(Carlo Kok) #1
One of our users gets an empty frontpage every time he first opens the discourse front page. the error is a TypeError in Chrome 32.0.1659.2 (dev channel); reproduces on meta.discourse.org too.
there’s nothing in the log when this happens and a refresh makes it work again, what could this possible be and how can I fix it? using HEAD from friday.
Errors:
Uncaught TypeError: Object function (){a||i.proto(),n(this,r,v),n(this,"super",v);var u=o(this),c=u.proto;if(u.proto=this,e){var p=e;e=null,this.reopen.apply(this,p)}if(t){var f=t;t=null;for(var d=this.concatenatedProperties,b=0,=f.length;>b;b++){var x=f[b];for(var w in x)if(x.hasOwnProperty(w)){var T=x[w],D=Ember.IS_BINDING;if(D.test(w)){var E=u.bindings;E?u.hasOwnProperty(“bindings”)||(E=u.bindings=s(u.bindings)):E=u.bindings={},E[w]=T}var C=u.descs[w];if(d&&y(d,w)>=0){var I=this[w];T=I?“function”==typeof I.concat?I.concat(T):Ember.makeArray(I).concat(T):Ember.makeArray(T)}C?C.set(this,w,T):“function”!=typeof this.setUnknownProperty||w in this?g?Ember.defineProperty(this,w,null,T):this[w]=T:this.setUnknownProperty(w,T)}}}m(this,u),this.init.apply(this,arguments),u.proto=c,h(this),l(this,“init”)} has no method ‘reopenClass’ application-6af5e3910565cd81791b5a899cb283e0.js:263
Uncaught TypeError: Object prototype may only be an Object or null admin-d15a0596f1e1170e6505b84917e49f6e.js:1
Uncaught TypeError: Cannot call method ‘call’ of undefined (index):102
>b;b++){var x=f[b];for(var w in x)if(x.hasOwnProperty(w)){var T=x[w],D=Ember.IS_BINDING;if(D.test(w)){var E=u.bindings;E?u.hasOwnProperty(“bindings”)||(E=u.bindings=s(u.bindings)):E=u.bindings={},E[w]=T}var C=u.descs[w];if(d&&y(d,w)>=0){var I=this[w];T=I?“function”==typeof I.concat?I.concat(T):Ember.makeArray(I).concat(T):Ember.makeArray(T)}C?C.set(this,w,T):“function”!=typeof this.setUnknownProperty||w in this?g?Ember.defineProperty(this,w,null,T):this[w]=T:this.setUnknownProperty(w,T)}}}m(this,u),this.init.apply(this,arguments),u.proto=c,h(this),l(this,“init”)} has no method ‘reopenClass’ application-6af5e3910565cd81791b5a899cb283e0.js:39
(Bill Ayakatubby) #2
I’ve reported errors here for Chrome dev in the past. The normal response from the devs is “beta/dev browsers aren’t supported.” Although to be fair, I’ve seen a few things like that suddenly work fine when that same dev version of Chrome made it to release.
(Jeff Atwood) #3
Beta/dev browsers aren’t supported.
If it is still an issue when this is a release version, please report it.
(Jeff Atwood) #4
