Unable to locate Onebox
(| full stack virgin) #1
tried installing onebox but to no avail.
(Joshua Rosenfeld) #2
I am very confused…onebox is part of Discourse, you don’t need to install it separately. All you need to do is whitelist domains that you wish to have oneboxed in site settings.
(| full stack virgin) #3
my bad…
actually, im not sure if one box is responding. been trying various links but i can’t seem to see the image.
on a different installation, this was working, but now, i’m not seeing any changes. @jomaxro
(Joshua Rosenfeld) #4
Have you ensured that linkedin is in the onebox domains whitelist?
(| full stack virgin) #5
ill try this one.
i’ve added it in the whitelist, and i’m still getting the same;
(Joshua Rosenfeld) #6
Well, it doesn’t work here on Meta, but I am not sure if it is whitelisted. Actually, does LinkedIn even support oEmbed or Open Graph? That’s kinda important.
(| full stack virgin) #7
ill with other websites that support oEmbed or OG. …
(| full stack virgin) #8
@jomaxro, i think it’s the website, doesn’t support any of those.
Thanks for the quick assistance.
