Unable to sign in to Discourse on mobile
(Jacqueline Mayne) #1
I’m having issues with the mobile version of the forums.
Everything is working fine on desktop, but on mobile I’m unable to do anything at all. All that is loading is a blank white screen with a log in/signup button. (shown below)
I can press the Sign Up button, but none of the other buttons work. I’m not even sure where to begin trouble shooting this. Is there something simple I’m missing? This was happening on an iPhone, but others at the office were getting varying degrees of the same issue.
(Jeff Atwood) #2
There was a bug around this recently so be sure to update to the very latest version of Discourse.
(Mittineague) #3
Hi Jacqueline welcome to the forum
Is it this Bug that was recently fixed?
(Jacqueline Mayne) #4
I’m currently running 1.7.0.beta7
(Jacqueline Mayne) #5
Hi, thanks for the welcome :slight_smile:
It does look like that bug, but I’m currently running the most up to date version and still having the issue.
(Jeff Atwood) #6
That is very unlikely, what you might mean is that we have not incremented the beta version since the fix. You need to update to latest.
(Jacqueline Mayne) #7
Ah, you’re right. Thanks so much for the prompt response!
