Unauthenticated users can see topics in private categories
(Michael Downey) #1
Continuing the discussion from “Sign In” vs. “Log Out”:
To clarify, they can not see the content, just that the topic exists and its title.
For an example, go to Categories - OpenMRS Talk (no log in necessary) and look under the “Meta” category and click some of the topics that appear there.
Subcategories do not inherit permissions from parent category
(cpradio) #2
Are you sure you have the permissions set right? As this doesn’t happen on our install and I can view the topics and their content (not logged in) in your Meta category.
(Michael Downey) #3
Sorry, let me clarify:
In our installation, the Meta category is not restricted in any way. However, there are a few sub-categories, e.g., Leadership, that do have restrictions in place:
Leadership can… Create / Reply / See
staff can… See
However, what you see in the view at Categories - OpenMRS Talk under the Meta parent category, shows several topics that exist under the “restricted” Leadership sub-category. While not signed in, if you click on most of those topics listed to the right, e.g., “Out-of-the-box software”, you’ll get the “You need to log in to see that topic” error message.
(cpradio) #4
Oh, that I definitely see :smile:
Our install doesn’t have this scenario, as we don’t have any public categories that have private sub-categories.
(Neil Lalonde) #5
This is a definitely a problem. I’ll have a look.
(Neil Lalonde) #6
I pushed a fix for it. Please give it a try when you can.
(Michael Downey) #7
Looks good at Categories - OpenMRS Talk - thanks! Although, the numbers calculated in the right-most column, e.g. “N / week”, seem to include the “invisible” topics too.
(Neil Lalonde) #8
Yeah that’s another issue… Will need to think about how to fix that issue. Having private sub-categories of a public category is a use case we haven’t seen before.
(Dave McClure) #9
We haven’t done this but we’ve talked about doing it. There are certainly cases where I can see where it’d make sense.
(Jeff Atwood) #10
