Uncaught ReferenceError: require is not defined
Hi guys!
After last update or maybe something else, I’m getting this in the root directory:
When I’m put /latest it works just fine! When, after visiting /latest, I go to root - it works until you update your page with F5 or Ctrl+F5.
Tried without luck:
  • safe mode
  • ./launcher rebuild app
Any ideas?
PS: I’m using cloudflare, if I’m directly connecting to my IP without cloudflare, it seems all is fine.
Then you can search here for “cloudflare” and find a bunch more reasons not to use cloudflare.
Thanks man, just in case I want to stick to cloudflare, any suggestions?
It seems you already know the suggestion?
Turn off all cloudflare “speed up by messing with the content” features.
Thanks.
Is there any chances that discourse would be fixed to support cloudflare?
Discourse isn’t the software with the problem. Feel free to open a ticket with CloudFlare.
