Undo all my SSL-related changes?
Hi everyone - I got my installation in a weird state. I made some mistakes renewing my SSL certificate, and the forums refused to load. I used a namecheap SSL cert. I overrode that by enabling letsencrypt instead. That seems to work fine, but the address bar still shows me as using the older namecheap SSL cert instead.
How do I reset everything and go back to setting SSL up from scratch?
Thanks,
Kirupa
Linux server. It is a digitalocean droplet running Ubuntu.
Rename your app.yml to something else and run discourse-setup.
Thanks Jay! To re-enable SSL on my discourse instance on digitalocean, can we use this guide: How To Install an SSL Certificate from a Commercial Certificate Authority | DigitalOcean Or should we use the discourse/docker-specific one here: Advanced Setup Only: Allowing SSL / HTTPS for your Discourse Docker setup
I would run ./discourse-setup and use a free and trouble-free Let’s Encrypt certificate.
Thanks! I will do that.
