Unicorns timing out during certain queries
Hey guys, just got hummingbird.me onto the latest Discourse (w/ Postgres and Redis hosted on infrastructure shared with the rest of our site and just a few client-heavy plugins) but we’re having some serious troubles with Unicorns timing out during certain queries. All three servers (web, postgres, redis) are running around 10% CPU and 50-60% RAM, there’s plenty of query slots remaining on the postgres server, and the cache hit rates aren’t unreasonable (most tables around 99%, with some with more random access like posts hovering around 50%)
Checking the Postgres logs pointed to some pretty hefty queries such as this lovely:
SELECT
a.id,
t.title, a.action_type, a.created_at, t.id topic_id,
t.closed AS topic_closed, t.archived AS topic_archived,
a.user_id AS target_user_id, au.name AS target_name, au.username AS target_username,
coalesce(p.post_number, 1) post_number, p.id as post_id,
p.reply_to_post_number,
pu.username, pu.name, pu.id user_id,
pu.uploaded_avatar_id,
u.username acting_username, u.name acting_name, u.id acting_user_id,
u.uploaded_avatar_id acting_uploaded_avatar_id,
coalesce(p.cooked, p2.cooked) cooked,
CASE WHEN coalesce(p.deleted_at, p2.deleted_at, t.deleted_at) IS NULL THEN false ELSE true END deleted,
p.hidden,
p.post_type,
p.action_code,
p.edit_reason,
t.category_id
FROM user_actions as a
JOIN topics t on t.id = a.target_topic_id
LEFT JOIN posts p on p.id = a.target_post_id
JOIN posts p2 on p2.topic_id = a.target_topic_id and p2.post_number = 1
JOIN users u on u.id = a.acting_user_id
JOIN users pu on pu.id = COALESCE(p.user_id, t.user_id)
JOIN users au on au.id = a.user_id
LEFT JOIN categories c on c.id = t.category_id
WHERE (t.deleted_at is null) AND (p.deleted_at is null and p2.deleted_at is null) AND (NOT COALESCE(p.hidden, false) OR p.user_id = -2) AND (COALESCE(p.post_type, p2.post_type) IN (1,2,3)) AND (t.visible) AND (a.action_type not in (3)) AND (a.action_type <> 14) AND (t.archetype != 'private_message') AND ((c.read_restricted IS NULL OR NOT c.read_restricted)) AND (a.user_id = 48321) AND (a.action_type in (4,5))
ORDER BY a.created_at desc
OFFSET 0
LIMIT 30
Which shows a pretty scary EXPLAIN:
        QUERY PLAN
 Limit  (cost=3523.95..3523.96 rows=1 width=622) (actual time=1735.823..1735.836 rows=30 loops=1)
   ->  Sort  (cost=3523.95..3523.96 rows=1 width=622) (actual time=1735.820..1735.829 rows=30 loops=1)
         Sort Key: a.created_at
         Sort Method: top-N heapsort  Memory: 46kB
         ->  Nested Loop  (cost=2.95..3523.94 rows=1 width=622) (actual time=0.231..1735.316 rows=289 loops=1)
               ->  Nested Loop  (cost=2.53..3515.50 rows=1 width=602) (actual time=0.228..1734.421 rows=289 loops=1)
                     ->  Nested Loop  (cost=2.12..3513.57 rows=1 width=582) (actual time=0.224..1733.551 rows=289 loops=1)
                           ->  Nested Loop  (cost=1.70..3506.19 rows=1 width=558) (actual time=0.201..1732.336 rows=289 loops=1)
                                 Join Filter: (COALESCE(p.post_type, p2.post_type) = ANY ('{1,2,3}'::integer[]))
                                 ->  Nested Loop Left Join  (cost=1.27..2873.24 rows=62 width=343) (actual time=0.165..1088.340 rows=289 loops=1)
                                       Filter: ((p.deleted_at IS NULL) AND ((NOT COALESCE(p.hidden, false)) OR (p.user_id = (-2))))
                                       ->  Nested Loop Left Join  (cost=0.84..1804.84 rows=128 width=91) (actual time=0.157..444.363 rows=289 loops=1)
                                             Join Filter: (c.id = t.category_id)
                                             Rows Removed by Join Filter: 6936
                                             Filter: ((c.read_restricted IS NULL) OR (NOT c.read_restricted))
                                             ->  Nested Loop  (cost=0.84..1748.15 rows=145 width=91) (actual time=0.102..441.141 rows=289 loops=1)
                                                   ->  Index Scan using idx_unique_rows on user_actions a  (cost=0.56..522.71 rows=217 width=32) (actual time=0.060..438.432 rows=297 loops=1)
                                                         Index Cond: ((action_type = ANY ('{4,5}'::integer[])) AND (user_id = 32418))
                                                   ->  Index Scan using forum_threads_pkey on topics t  (cost=0.29..5.64 rows=1 width=59) (actual time=0.007..0.008 rows=1 loops=297)
                                                         Index Cond: (id = a.target_topic_id)
                                                         Filter: ((deleted_at IS NULL) AND visible AND ((archetype)::text <> 'private_message'::text))
                                                         Rows Removed by Filter: 0
                                             ->  Materialize  (cost=0.00..2.38 rows=25 width=5) (actual time=0.000..0.005 rows=25 loops=289)
                                                   ->  Seq Scan on categories c  (cost=0.00..2.25 rows=25 width=5) (actual time=0.003..0.031 rows=25 loops=1)
                                       ->  Index Scan using posts_pkey on posts p  (cost=0.43..8.33 rows=1 width=256) (actual time=2.226..2.227 rows=1 loops=289)
                                             Index Cond: (id = a.target_post_id)
                                 ->  Index Scan using index_posts_on_topic_id_and_post_number on posts p2  (cost=0.43..10.17 rows=3 width=227) (actual time=2.226..2.227 rows=1 loops=289)
                                       Index Cond: ((topic_id = t.id) AND (post_number = 1))
                                       Filter: (deleted_at IS NULL)
                           ->  Index Scan using users_pkey on users u  (cost=0.42..7.37 rows=1 width=28) (actual time=0.002..0.003 rows=1 loops=289)
                                 Index Cond: (id = a.acting_user_id)
                     ->  Index Scan using users_pkey on users pu  (cost=0.42..1.92 rows=1 width=28) (actual time=0.001..0.002 rows=1 loops=289)
                           Index Cond: (id = COALESCE(p.user_id, t.user_id))
               ->  Index Scan using users_pkey on users au  (cost=0.42..8.44 rows=1 width=24) (actual time=0.001..0.002 rows=1 loops=289)
                     Index Cond: (id = 48321)
 Planning time: 9.415 ms
 Execution time: 1736.177 ms
(37 rows)
The first time I ran this query through explain, it gave a 20-second execution time :confused: I’m not 100% sure I’m reading this correctly (mostly because it’s so absurd it made me question my senses) but is that 7 loops nested?
Any tips? I’m thinking of switching our deploy to Puma because a slow response is better than no-response-and-the-server-dies-resulting-in-other-requests-failing, but I’d rather stay vanilla.
Since you just moved did you vacuum analyze the entire discourse db? It can really helps!
Also, you postgresql config is tunned? shared buffers, and cia sucks on default values.
I highly do not recommend you deviate from the Discourse defaults. And double check to make sure you’ve given the DB tons of memory it can actually use via postgres config.
@sam can have a peek and advise.
Ran that overnight, to no avail. Still seeing the same ugly query plan with the same absurd execution times (20-40 seconds)
We’re on RDS defaults right now, which are relatively well-tuned tuned by default — not perfect, but significantly better than Postgres’ defaults, since they’re all pinned relative to the instance’s memory size. I can probably bump the shared_buffers a bit, possibly up to like 30-40% since we don’t have much RAM pressure.
I will say that we were seeing similar issues when we were running our old Discourse 1.2 on DigitalOcean, forcing us to restart the docker container every day or two.
I suspect the underlying problem was exacerbated by RDS having higher IO latency than DigitalOcean, but I can’t give values to back that up.
I’d like to avoid it at all costs, it only makes my life significantly harder. I only ditched the builtin Postgres and Redis instances because I’m trying to reduce infrastructure redundancy (and the overhead that it brings) — plus some past bad experiences with DigitalOcean spontaneously null-routing our server, it disappearing from the admin panel, and backups causing downtime. That said, since we’re seemingly IO-bound (since there’s no pressure on CPU or RAM), Puma might be a good option for us. GIL isn’t a problem in that situation.
At least Puma would still serve other requests while some of them are waiting on Postgres.
Ah yes, server specs would probably help. Both our database server and web server have 2 CPUs and 4GB of RAM (both just for Discourse right now, as we haven’t yet moved our primary service to it). shared_buffers is tuned to approximately 1GB, and everything else seems to be properly tuned based on the Postgres tuning guide
Edit: seeing another strange situation where some Sidekiq tasks are stalling and taking 15+ minutes to run. Our backlog is up to 2000. Might be related? I’m bumping our Unicorns and Sidekiqs up as well as db pool size to see if that can help mask issues for now
Edit 2: The vacuum analyze is still apparently running, 18 hours later. So, it seems, are two badge-grant queries (at 19 hours each)
Edit 3: Unicorn and Sidekiq bumps didn’t help so I took our web server down for now, bumped maintanence_work_mem and shared_buffers to 1.5GB each, restarted the database and am re-running vacuum verbose analyze now. post_timings and email_logs took a long-ass time to vacuum, is there any fancy magic task to coalesce/truncate old data in those? post_timings alone has 53.9M rows, email_logs has 6.8M rows. That’s significantly more than our 1.1M in posts or 28.9K in topics
  estimate  |              table_name
 53 987 640 | post_timings
  7 035 955 | topic_views
  6 806 784 | email_logs
  5 178 547 | user_actions
  4 146 465 | user_visits
  3 961 823 | incoming_links
  2 782 003 | topic_users
  1 194 096 | post_search_data
  1 141 633 | posts
  1 078 389 | notifications
Edit 4: Vacuuming is complete, turned the web server back on. Still facing the same problems, and it appears that Jobs::NotifyMailingListSubscribers and Jobs::UserEmail are slowed by the size of email_logs. All the queries are taking on the order of 5+ minutes.
I wouldn’t be surprised if that was at least a contributing factor to your DB performance woes. I’ve never had the guts to run PgSQL on RDS, but the performance of the MySQL RDS instances I was responsible for a couple of years ago was woeful compared to running on bare metal. The monster SELECT query you mentioned in your initial post takes 150ms on one of our Enterprise customer’s DB (540GiB in /var/lib/postgresql/9.5/data), so there’s no reason why it has to be taking so long on your setup (other than things like “RDS is pants”).
That query only happens on the user page, it has gone through quite a bit of tuning, very surprised it is taking so long there.
On meta:
 SELECT
        a.id,
        p.hidden,
        p.post_type,
        p.action_code,
        p.edit_reason,
        t.category_id
      WHERE (t.deleted_at is null) AND (COALESCE(p.post_type, p2.post_type) IN (1,2,3,4)) AND (a.user_id = 8486) AND (a.action_type in (4,5))
      OFFSET 0
      LIMIT 30
Takes 5 milliseconds.
#1 recommendation use our docker based pg install.
I ended up tweaking the postgres config to boost caching and upgrading the IO for the instance and the problem seems to have gone away. Significantly faster than when we were running on DigitalOcean and using the docker-based postgres install, so our users are happy (and so are we, because we get to save money in the process!)
Either way, resolved :white_check_mark:
Whatever happened to this site @Nuck – it used to be hugely popular, as I recall?
https://www.crunchyroll.com/forumtopic-860701/hummingbird-or-myanimelist
