Unknown error in logs
(Joe Buhlig) #1
I just launched a new community yesterday and I know it takes time to build a user base so there isn’t much for traffic there yet. But just for my own sanity I took a look at the error logs and ran across this error that shows up fairly frequently:
I’m not sure where to start in hunting this down. I took a look at the file in question, but couldn’t see anything helpful. The backtrace is empty. I’m on the latest build. Anyone have ideas?
(Sam Saffron) #2
We can’t do much with those errors, especially since we have not much context.
How does this issue manifest itself? Can you reproduce the issue?
(Jeff Atwood) #3
Are you running third party Discourse plugins of any kind? If so disable them.
Do you have javascript customizations in Admin, Customize? If so disable them.
(Joe Buhlig) #4
Sorry for the ambiguity. I’m having a hard time finding context myself. I’m in the middle of testing Jeff’s recommendation but I haven’t found anything yet.
Are these js errors logged with a traceback anywhere? I was looking through the file structure (one-click docker install from DO) but was having a hard time finding the logs. I have a decent amount of experience with the Ruby/Rails side of things but Ember is completely new (and a bit confusing) to me at the moment.
