IP address of users showing as server IP
Hi,
We have a new install of discourse (thanks btw). When I look at it addresses in the admin panel, all users are showing an IP address of the server rather than the user.
Thoughts on where I should start looking?
That suggests a reverse proxy exists in your installation. How was your server installed?
Are you using Cloudflare?
Hi Stephen, you are correct - this is a reverse proxy install. The real IP is sent to nginx in the docker via a different header.
Is there a way to match the user’s IP address to the new header vs the default remote_addr?
See How to set up Discourse on a server with existing Apache sites
Thanks, that worked. [solved]
