"Up to date" or not?
#1
Continuing the discussion from Broken "Welcome To" after last upgrade:
All right, excuse my ignorance with github, but how could I compare my actual version with the last version of discourse without enter to /admin/upgrade ?
(Jeff Atwood) #2
If you are out of date enough (beta3 vs. beta4) you will be notified on the admin dashboard. If you are only mildly out of date (beta5 +23 vs. beta5 +40) you must visit the upgrade page directly.
Simply view source to see your current version from any location. Or visit /admin to see the version at the top of the admin dashboard.
#3
Thanks.
Right now in my spanish forum:
But., if I went to /admin/upgrade
Why? :’(
Thats why I need to compare versions from other site (such as github, for example).
But I don’t know how to do it.
(Jeff Atwood) #4
Simply follow the instructions printed on your screenshot.
I don’t understand what your question is. Follow the instructions on your screen.
(Tarak'ha) #5
I gently suggest the idea to change that copy.
Eg:
You are running an old version of the Discourse image.
Upgrades via the web UI are disabled until you run the latest image.
To run the latest image and re-gain access to the web UI, please log in to your server using SSH and run:
<cmd>
(Sam Saffron) #6
I am not sure putting more words on the screen will solve this particular problem
#7
I understand that with the instructions on the screen capture the problem is solved. What I wanted to ask this issue was how to compare my current version against the version of the image of Discourse (official).
Since the /admin for more than said that I’m updated, what actually happens is that I was running a version of the old image.
That’s all.
Ps, excuse my English.
(Sam) #8
Ah, so basically is there a way to know whether or not SSH + git pull will do anything without actually SSH’ing into your server and running git pull?
As far as I know, no, but that shouldn’t really be any issue. Discourse seems to do a good job of notifying you when running this particular update (which is a separate update from what you run at /admin/upgrade and see on the dashboard at /admin) is necessary. As you have just seen. :smile:
And when it’s not necessary, well, it’s not necessary.
