Update is not synchronized
(Renis) #1
I was trying to update from admin panel, and as the update didn’t go through I did a rollback to update from terminal. Now git pull is
Already up-to-date.
from admin panel:
Version v1.7.0.beta8 +39 1.8.0.beta4 Updates are available. Please upgrade!
tried to run rebuild for several times.
./launcher rebuild app
But it doesn’t update…
(Renis) #2
I did a clean up and rebuild. but now saying is downloading 1.3.10 :confused:
Unable to find image 'discourse/discourse:1.3.10' locally
1.3.10: Pulling from discourse/discourse
(Andrew Waugh) #3
The version numbers of the docker containers aren’t the same as the version numbers shown in /admin.
As I understand it, The docker image:1.3.10 contains discourse:1.8.0.beta4, and the +nn are patches to that.
(Renis) #4
Ah, okay didn’t know that! Thank you @JagWaugh
docker images
REPOSITORY             TAG                 IMAGE ID            CREATED             SIZE
local_discourse/app    latest              1b6885202cfd        7 minutes ago       2.41 GB
discourse/discourse    1.3.10              1881a9bd3afd        4 weeks ago         1.54 GB
samsaffron/docker-gc   latest              54ca424ca8d6        15 months ago       57.7 MB
is ok to delete the last row?
(Andrew Waugh) #5
I’m not sure what happens if you do. It’s only 57 MB.
If you watch what happens when you do ./launcher upgrade app you will see that docker-gc gets pulled and loaded, I think it is a sort of “helper” container which does some of the work while upgrading.
(Mittineague) #6
Only a wild guess here, but to me “gc” suggests it has something to do with “Garbage Collection”
I’m thinking it may be a type of “trash folder” that might come in useful if you need to roll things back with a “restore”.
(Felix Freiberger) #7
I’m pretty sure that the docker-gc image implements the launcher cleanup command :slight_smile:
(Andrew Waugh) #8
If you run docker stats in a separate window when you are doing ./launcher rebuild app and such you will see that various images are pulled and started.
Don’t confuse me with an expert… I’m still at the stage of poking it with a stick to see what it does.
