Update to 1.9.0.beta5 fails to start discourse after rebuild
(Iceman) #1
Hi guys,
Just updated to 1.9.0.beta5 and after doing an App Rebuild (same process as always) I get this error:
./launcher: line 256: selinuxenabled: command not found
The Discourse Installation then loads to a white page, nothing else.
Any ideas on how to fix this?
I can provide more info if needed.
Thanks in Advance!
Error when launcher bootstrapping (Permission denied)
(Jeff Atwood) #2
Yes this is a change @sam merged in from @db48x looks like we need to revert that change.
(Iceman) #3
Is there a way of “rolling back” the repository in the local macchine to a previous state to rebuild?
Thanks Jeff!
(Sam Saffron) #4
Good call, reverted now.
(Iceman) #5
Hi @sam ,
First of all, thanks for the quick-fix.
Just a doubt, I pulled the code again, now it rebuilds without that error but the discourse installation still appears blank. Can that be related? Maybe I’m missing something, a cache cleanup or something like that?
BTW: For some reason the disk usage of the machine that cointained Discourse (and only Discourse) increased by 20%. Don’t know if it may be related, just to point it out, as just happened with the update process.
Update 2: I can confirm that the increments are consistent with every time I rebuild the app, never happened on previous updates:
(Felix Freiberger) #6
The disk usage increase is normal, Launcher will not delete old images until you run ./launcher cleanup :slight_smile:
It’s most likely unrelated and is typically caused by plugins or site customizations. Try browsing to /safe-mode on your site to enable safe mode – if your site works then, it’s one of these.
If safe mode doesn’t help, it may still be a plugin – comment out any line cloning a plugin not coming from https://github.com/discourse/ and rebuild. Does this help?
(Iceman) #7
Thank you so much.
I didn’t knew the Cleanup command/trick, out of nowhere so much free space… :stuck_out_tongue: Thanks!
And the issue, yes, it was a plugin. After hunting around I found this:
Everything is working now as intended. Thanks to @fefrei, @sam and @codinghorror! You guys are great!
