Updating Discourse from git?
#1
This is probably a question that has been asked before, but I couldnt quite find the answer I was looking for.
I installed Discourse using the official installation guide for a Docker install. From what I can tell it seems that installing Discourse this way checks out the latest code from the Github repo? If so, will running launcher rebuild update Discourse with the latest git commits as well? If not, then what is the recommended way to stay up to date?
Best regards
Upgrade link should always be visible (or as long as there are new commits)
(Florian Beer) #2
Just go to yourdomain.tld/admin/upgrade and marvel in the awesomeness that is provided for you :wink:
#3
So much awesomeness! Thanks!
(Florian Beer) #4
Do it as often as possible, it’s said to prolong your life expectancy :sunny:
(Régis Hanol) #5
One upgrade a day keeps the doctor away
:wink:
(cpradio) #6
I like my version:
One upgrade a day keeps the hackers at bay
:wink:
