Upgrade after problem
(Hakan) #1
Hello im upgrade now but after error ./launcher rebuild app
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 14104 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
1e07e60118b253462e7bb631ca11ee5fc4263a025d5d8819c9d3c9cb37ad803d
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
(Matt Palmer) #2
Did you read the error message you posted?
(Hakan) #3
when I add the plugin I get this error. why
(Mittineague) #4
Because of something that was logged in the “scroll up” portion that you haven’t shown.
(Jeff Atwood) #5
Perhaps the plugin is broken? Try building without it.
(Hakan) #6
Header search plugin remove. and problem solved.
(Angus McLeod) #7
Thanks for the report.
I am removing support for the Header Search Plugin and will only be supporting the Header Search Theme in the future.
You can see the Header Search Theme in working order, running the latest Discourse, on my sandbox.
