Upgrade failed after the recent today's commits: «cannot load such file -- rails_multisite»
(Discourse.PRO) #1
https://github.com/discourse/discourse/commit/cf52671feb11238e860a97ff797e521830d47553
Tested in Vagrant.
LoadError: cannot load such file – rails_multisite
/var/lib/gems/2.2.0/gems/bundler-1.9.4/lib/bundler/runtime.rb:76:in require' /var/lib/gems/2.2.0/gems/bundler-1.9.4/lib/bundler/runtime.rb:76:inblock (2 levels) in require’
/var/lib/gems/2.2.0/gems/bundler-1.9.4/lib/bundler/runtime.rb:72:in each' /var/lib/gems/2.2.0/gems/bundler-1.9.4/lib/bundler/runtime.rb:72:inblock in require’
/var/lib/gems/2.2.0/gems/bundler-1.9.4/lib/bundler/runtime.rb:61:in each' /var/lib/gems/2.2.0/gems/bundler-1.9.4/lib/bundler/runtime.rb:61:inrequire’
/var/lib/gems/2.2.0/gems/bundler-1.9.4/lib/bundler.rb:134:in require' /vagrant/config/application.rb:15:in<top (required)>’
/vagrant/Rakefile:5:in require' /vagrant/Rakefile:5:in<top (required)>’
Vagrant based server failing on db:migrate
Discourse as Your First Rails App
Rails Multisite still breaking build
(Régis Hanol) #2
I cannot reproduce this issue. I just successfully upgraded http://discourse.codinghorror.com to latest.
#3
I encountered the same problem after upgrading.
I did followings to fix it.
Add this in Gemfile before line 41
gem 'rails_multisite'
and then it’ll complain that it can’t load
/var/lib/gems/2.2.0/gems/rails_multisite_discourse-
1.0.1/lib/rails_multisite/../tasks/generators.rake
just go into the directory and run command
sudo chmod a+r generators.rake
Now, db:migrate will execute correctly.
(Sam Saffron) #4
it was broken for 1 commit, perhaps rubygems did not propagate fast enough, still an issue?
(Jeff Atwood) #5
(Matt Palmer) #6
There are actually several files with the restrictive permissions. You’ll need to run:
sudo chmod -R a+r /var/lib/gems/2.2.0/gems/rails_multisite-1.0.1
To fix them all up.
