Upgrade, force SSL, Emails not working on Bitnami install
unsupported-install
(Rohit Manglik) #1
Hi,
I installed discourse today using Bitnami image in AWS and I am stuck in a few places
  1. As mentioned everywhere in the internet, /admin/upgrade should give an option to upgrade discourse but in my case, it’s showing That page doesn’t exist or is private
  1. I enabled force https but still I can access both versions of site - http://iitjee.edugorilla.com and https://iitjee.edugorilla.com
  2. I am able to send test email but for password reset email, emails are not sent. I checked in all the tabs (Sent, Skipped, bounce etc) but that password reset email is not present.
I tested it many times but the error persists.
Regards
Rohit
(Felix Freiberger) #2
You are using an unsupported install, and all three issues are typical for broken Bitnami installs :frowning:
You should take a backup of your current installation, re-install using the official instructions and restore your backup. :slight_smile:
(Rohit Manglik) #3
@fefrei can you please confirm whether the open source version support Frontend upgrade?
Ref: Upgrade, force SSL, Emails not working - Discourse - Bitnami Community
(Jay Pfaffman) #4
If you follow the official install instructions he linked, then upgrades, and everything else described on this site will work as described here on this site.
If you install some other way, you are on your own.
(Rohit Manglik) #5
I concur.
Thanks. I deleted the Bitnami image and created a new instance from scratch with all latest versions.
Thanks for your help.
Discourse has stopped working after LetsEncrypt is enabled
(Rohit Manglik) #6
Help help help!
I created another instance in AWS and followed the official guide this time. I am using latest version of all the services.
I tried with two SMTP Servers: Sparkpost and SendInBlue. I am able to send test email and it works smoothly:
However, when I send password reset email or account creation email, I never receive it. I checked in my email server log and found that no email is triggered from Discourse. I invested 5 hours into this and no help!
I even repeated whole procedure twice and searched online but cannot find any solution.
Please guide!
(Sam Saffron) #7
Try signing up to a different email provider… maybe your email provider has problems… try sendgrid or any of the other one’s out there.
(Rohit Manglik) #8
Hi @sam, I already tried SendInBlue and Sparkpost.
Sparkpost officially supports Discourse: Using SparkPost with Discourse - SparkPost
I belive there is some coding issue in Discourse. Is it possible to debug in my environment or I can create a test environment for you.
(Rohit Manglik) #9
Also can you please confirm whether the request should be sent from https site.
(Felix Freiberger) #10
Maybe this is related to Discourse running under a naked IP address instead of an actual domain? Try setting the A record of your target domain to your IP address, changing the hostname in app.yml and rebuilding.
If that doesn’t help, go to http://www.mail-tester.com/, let Discourse send a test email to the address you are given there and send us a screenshot of the report you are given.
(Sam Saffron) #11
For the record, running under a naked IP is not a supported config.
(Rohit Manglik) #12
Thanks @fefrei
I updated the domain name. Now it’s https://iitjee.edugorilla.com
Here is the screenshot of mail-tester.com:
It’s still not working.
(Felix Freiberger) #13
Hm, strange. Is there anything interesting in /logs?
(Rohit Manglik) #14
Sorry, how to check that? Do you mean through sudo ./launcher logs app
Here is the complete log:
ubuntu@ip-172-31-0-252:/var/discourse$ sudo ./launcher logs app
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
run-parts: executing /etc/runit/1.d/enable-brotli
run-parts: executing /etc/runit/1.d/letsencrypt
[Tue Jun 20 20:59:02 UTC 2017] Domains not changed.
[Tue Jun 20 20:59:02 UTC 2017] Skip, Next renewal time is: Sat Aug 19 16:38:53 UTC 2017
[Tue Jun 20 20:59:02 UTC 2017] Add '--force' to force to renew.
[Tue Jun 20 20:59:02 UTC 2017] Installing key to:/shared/ssl/iitjee.edugorilla.com.key
[Tue Jun 20 20:59:02 UTC 2017] Installing full chain to:/shared/ssl/iitjee.edugorilla.com.cer
[Tue Jun 20 20:59:02 UTC 2017] Run reload cmd: sv reload nginx
warning: nginx: unable to open supervise/ok: file does not exist
[Tue Jun 20 20:59:02 UTC 2017] Reload error for :
Started runsvdir, PID is 215
sh: echo: I/O error
ok: run: redis: (pid 227) 0s
ok: run: postgres: (pid 225) 0s
rsyslogd: command 'KLogPermitNonKernelFacility' is currently not permitted - did you already set it via a RainerScript command (v6+ config)? [v8.16.0 try http://www.rsyslog.com/e/2222 ]
rsyslogd: imklog: cannot open kernel log (/proc/kmsg): Operation not permitted.
rsyslogd: activation of module imklog failed [v8.16.0 try http://www.rsyslog.com/e/2145 ]
				_._
		   _.-``__ ''-._
	  _.-``    `.  `_.  ''-._           Redis 3.0.6 (00000000/0) 64 bit
  .-`` .-```.  ```\/    _.,_ ''-._
 (    '      ,       .-`  | `,    )     Running in standalone mode
 |`-._`-...-` __...-.``-._|'` _.-'|     Port: 6379
 |    `-._   `._    /     _.-'    |     PID: 227
  `-._    `-._  `-./  _.-'    _.-'
 |`-._`-._    `-.__.-'    _.-'_.-'|
 |    `-._`-._        _.-'_.-'    |           http://redis.io
  `-._    `-._`-.__.-'_.-'    _.-'
 |    `-._`-._        _.-'_.-'    |
	  `-._    `-.__.-'    _.-'
		  `-._        _.-'
			  `-.__.-'
227:M 20 Jun 20:59:02.644 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
227:M 20 Jun 20:59:02.644 # Server started, Redis version 3.0.6
227:M 20 Jun 20:59:02.644 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
227:M 20 Jun 20:59:02.644 # WARNING you have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command 'echo never > /sys/kernel/mm/transparent_hugepage/enabled' as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled.
rsyslogd: Could not open output pipe '/dev/xconsole':: No such file or directory [v8.16.0 try http://www.rsyslog.com/e/2039 ]
227:M 20 Jun 20:59:02.653 * DB loaded from disk: 0.008 seconds
227:M 20 Jun 20:59:02.653 * The server is now ready to accept connections on port 6379
supervisor pid: 223 unicorn pid: 238
2017-06-20 20:59:02.811 UTC [240] LOG:  database system was shut down at 2017-06-20 20:58:26 UTC
2017-06-20 20:59:02.817 UTC [240] LOG:  MultiXact member wraparound protections are now enabled
2017-06-20 20:59:02.824 UTC [225] LOG:  database system is ready to accept connections
2017-06-20 20:59:02.828 UTC [245] LOG:  autovacuum launcher started
227:M 20 Jun 21:04:03.098 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:04:03.099 * Background saving started by pid 1207
1207:C 20 Jun 21:04:03.110 * DB saved on disk
1207:C 20 Jun 21:04:03.110 * RDB: 2 MB of memory used by copy-on-write
227:M 20 Jun 21:04:03.200 * Background saving terminated with success
227:M 20 Jun 21:09:04.012 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:09:04.012 * Background saving started by pid 1617
1617:C 20 Jun 21:09:04.025 * DB saved on disk
1617:C 20 Jun 21:09:04.026 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:09:04.112 * Background saving terminated with success
227:M 20 Jun 21:14:05.098 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:14:05.099 * Background saving started by pid 1957
1957:C 20 Jun 21:14:05.108 * DB saved on disk
1957:C 20 Jun 21:14:05.109 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:14:05.199 * Background saving terminated with success
227:M 20 Jun 21:19:06.099 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:19:06.100 * Background saving started by pid 2305
2305:C 20 Jun 21:19:06.109 * DB saved on disk
2305:C 20 Jun 21:19:06.109 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:19:06.201 * Background saving terminated with success
227:M 20 Jun 21:24:07.004 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:24:07.004 * Background saving started by pid 2657
2657:C 20 Jun 21:24:07.013 * DB saved on disk
2657:C 20 Jun 21:24:07.014 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:24:07.105 * Background saving terminated with success
227:M 20 Jun 21:29:08.095 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:29:08.095 * Background saving started by pid 3027
3027:C 20 Jun 21:29:08.110 * DB saved on disk
3027:C 20 Jun 21:29:08.111 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:29:08.195 * Background saving terminated with success
227:M 20 Jun 21:34:09.088 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:34:09.088 * Background saving started by pid 3384
3384:C 20 Jun 21:34:09.098 * DB saved on disk
3384:C 20 Jun 21:34:09.098 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:34:09.188 * Background saving terminated with success
227:M 20 Jun 21:39:10.080 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:39:10.080 * Background saving started by pid 3720
3720:C 20 Jun 21:39:10.089 * DB saved on disk
3720:C 20 Jun 21:39:10.090 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:39:10.180 * Background saving terminated with success
227:M 20 Jun 21:44:11.100 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:44:11.100 * Background saving started by pid 4053
4053:C 20 Jun 21:44:11.109 * DB saved on disk
4053:C 20 Jun 21:44:11.110 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:44:11.201 * Background saving terminated with success
227:M 20 Jun 21:49:12.004 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:49:12.005 * Background saving started by pid 4391
4391:C 20 Jun 21:49:12.014 * DB saved on disk
4391:C 20 Jun 21:49:12.014 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:49:12.105 * Background saving terminated with success
227:M 20 Jun 21:54:13.013 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:54:13.014 * Background saving started by pid 4723
4723:C 20 Jun 21:54:13.024 * DB saved on disk
4723:C 20 Jun 21:54:13.024 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:54:13.114 * Background saving terminated with success
227:M 20 Jun 21:59:14.016 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 21:59:14.016 * Background saving started by pid 5053
5053:C 20 Jun 21:59:14.033 * DB saved on disk
5053:C 20 Jun 21:59:14.033 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 21:59:14.117 * Background saving terminated with success
227:M 20 Jun 22:04:15.025 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:04:15.025 * Background saving started by pid 5389
5389:C 20 Jun 22:04:15.039 * DB saved on disk
5389:C 20 Jun 22:04:15.040 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:04:15.125 * Background saving terminated with success
227:M 20 Jun 22:09:16.055 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:09:16.055 * Background saving started by pid 5721
5721:C 20 Jun 22:09:16.066 * DB saved on disk
5721:C 20 Jun 22:09:16.066 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:09:16.155 * Background saving terminated with success
227:M 20 Jun 22:14:17.076 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:14:17.076 * Background saving started by pid 6050
6050:C 20 Jun 22:14:17.086 * DB saved on disk
6050:C 20 Jun 22:14:17.086 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:14:17.177 * Background saving terminated with success
227:M 20 Jun 22:19:18.099 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:19:18.099 * Background saving started by pid 6388
6388:C 20 Jun 22:19:18.108 * DB saved on disk
6388:C 20 Jun 22:19:18.109 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:19:18.199 * Background saving terminated with success
227:M 20 Jun 22:24:19.008 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:24:19.008 * Background saving started by pid 6717
6717:C 20 Jun 22:24:19.017 * DB saved on disk
6717:C 20 Jun 22:24:19.018 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:24:19.109 * Background saving terminated with success
227:M 20 Jun 22:29:20.021 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:29:20.021 * Background saving started by pid 7050
7050:C 20 Jun 22:29:20.031 * DB saved on disk
7050:C 20 Jun 22:29:20.031 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:29:20.122 * Background saving terminated with success
227:M 20 Jun 22:34:21.002 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:34:21.002 * Background saving started by pid 7384
7384:C 20 Jun 22:34:21.014 * DB saved on disk
7384:C 20 Jun 22:34:21.015 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:34:21.102 * Background saving terminated with success
227:M 20 Jun 22:39:22.024 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:39:22.024 * Background saving started by pid 7715
7715:C 20 Jun 22:39:22.033 * DB saved on disk
7715:C 20 Jun 22:39:22.033 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:39:22.125 * Background saving terminated with success
227:M 20 Jun 22:44:23.026 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:44:23.026 * Background saving started by pid 8044
8044:C 20 Jun 22:44:23.035 * DB saved on disk
8044:C 20 Jun 22:44:23.035 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:44:23.126 * Background saving terminated with success
227:M 20 Jun 22:49:24.011 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:49:24.011 * Background saving started by pid 8382
8382:C 20 Jun 22:49:24.020 * DB saved on disk
8382:C 20 Jun 22:49:24.020 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:49:24.111 * Background saving terminated with success
227:M 20 Jun 22:54:25.015 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:54:25.015 * Background saving started by pid 8714
8714:C 20 Jun 22:54:25.024 * DB saved on disk
8714:C 20 Jun 22:54:25.024 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:54:25.115 * Background saving terminated with success
227:M 20 Jun 22:59:26.003 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 22:59:26.004 * Background saving started by pid 9047
9047:C 20 Jun 22:59:26.013 * DB saved on disk
9047:C 20 Jun 22:59:26.013 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 22:59:26.104 * Background saving terminated with success
227:M 20 Jun 23:04:27.014 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:04:27.015 * Background saving started by pid 9384
9384:C 20 Jun 23:04:27.024 * DB saved on disk
9384:C 20 Jun 23:04:27.024 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:04:27.115 * Background saving terminated with success
227:M 20 Jun 23:09:28.017 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:09:28.017 * Background saving started by pid 9717
9717:C 20 Jun 23:09:28.026 * DB saved on disk
9717:C 20 Jun 23:09:28.026 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:09:28.117 * Background saving terminated with success
227:M 20 Jun 23:14:29.026 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:14:29.027 * Background saving started by pid 10050
10050:C 20 Jun 23:14:29.035 * DB saved on disk
10050:C 20 Jun 23:14:29.036 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:14:29.127 * Background saving terminated with success
227:M 20 Jun 23:19:30.026 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:19:30.027 * Background saving started by pid 10392
10392:C 20 Jun 23:19:30.035 * DB saved on disk
10392:C 20 Jun 23:19:30.036 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:19:30.127 * Background saving terminated with success
227:M 20 Jun 23:24:31.066 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:24:31.066 * Background saving started by pid 10721
10721:C 20 Jun 23:24:31.075 * DB saved on disk
10721:C 20 Jun 23:24:31.075 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:24:31.166 * Background saving terminated with success
227:M 20 Jun 23:29:32.055 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:29:32.056 * Background saving started by pid 11061
11061:C 20 Jun 23:29:32.064 * DB saved on disk
11061:C 20 Jun 23:29:32.065 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:29:32.156 * Background saving terminated with success
227:M 20 Jun 23:34:33.070 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:34:33.071 * Background saving started by pid 11396
11396:C 20 Jun 23:34:33.079 * DB saved on disk
11396:C 20 Jun 23:34:33.080 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:34:33.171 * Background saving terminated with success
227:M 20 Jun 23:39:34.089 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:39:34.089 * Background saving started by pid 11728
11728:C 20 Jun 23:39:34.110 * DB saved on disk
11728:C 20 Jun 23:39:34.111 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:39:34.190 * Background saving terminated with success
227:M 20 Jun 23:44:35.095 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:44:35.095 * Background saving started by pid 12061
12061:C 20 Jun 23:44:35.104 * DB saved on disk
12061:C 20 Jun 23:44:35.104 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:44:35.195 * Background saving terminated with success
227:M 20 Jun 23:49:36.085 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:49:36.086 * Background saving started by pid 12401
12401:C 20 Jun 23:49:36.097 * DB saved on disk
12401:C 20 Jun 23:49:36.098 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:49:36.186 * Background saving terminated with success
227:M 20 Jun 23:54:37.092 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:54:37.092 * Background saving started by pid 12729
12729:C 20 Jun 23:54:37.101 * DB saved on disk
12729:C 20 Jun 23:54:37.101 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:54:37.192 * Background saving terminated with success
227:M 20 Jun 23:59:38.101 * 10 changes in 300 seconds. Saving...
227:M 20 Jun 23:59:38.102 * Background saving started by pid 13067
13067:C 20 Jun 23:59:38.116 * DB saved on disk
13067:C 20 Jun 23:59:38.117 * RDB: 0 MB of memory used by copy-on-write
227:M 20 Jun 23:59:38.202 * Background saving terminated with success
227:M 21 Jun 00:04:39.015 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:04:39.016 * Background saving started by pid 13740
13740:C 21 Jun 00:04:39.024 * DB saved on disk
13740:C 21 Jun 00:04:39.025 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:04:39.116 * Background saving terminated with success
227:M 21 Jun 00:09:40.021 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:09:40.021 * Background saving started by pid 14074
14074:C 21 Jun 00:09:40.030 * DB saved on disk
14074:C 21 Jun 00:09:40.031 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:09:40.121 * Background saving terminated with success
227:M 21 Jun 00:14:41.029 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:14:41.029 * Background saving started by pid 14406
14406:C 21 Jun 00:14:41.048 * DB saved on disk
14406:C 21 Jun 00:14:41.049 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:14:41.130 * Background saving terminated with success
227:M 21 Jun 00:19:42.013 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:19:42.013 * Background saving started by pid 14748
14748:C 21 Jun 00:19:42.028 * DB saved on disk
14748:C 21 Jun 00:19:42.029 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:19:42.113 * Background saving terminated with success
227:M 21 Jun 00:24:43.039 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:24:43.039 * Background saving started by pid 15078
15078:C 21 Jun 00:24:43.054 * DB saved on disk
15078:C 21 Jun 00:24:43.054 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:24:43.140 * Background saving terminated with success
227:M 21 Jun 00:29:44.021 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:29:44.021 * Background saving started by pid 15416
15416:C 21 Jun 00:29:44.030 * DB saved on disk
15416:C 21 Jun 00:29:44.030 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:29:44.121 * Background saving terminated with success
227:M 21 Jun 00:34:45.027 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:34:45.027 * Background saving started by pid 15754
15754:C 21 Jun 00:34:45.042 * DB saved on disk
15754:C 21 Jun 00:34:45.042 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:34:45.127 * Background saving terminated with success
227:M 21 Jun 00:39:46.039 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:39:46.040 * Background saving started by pid 16088
16088:C 21 Jun 00:39:46.048 * DB saved on disk
16088:C 21 Jun 00:39:46.049 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:39:46.140 * Background saving terminated with success
227:M 21 Jun 00:44:47.053 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:44:47.054 * Background saving started by pid 16422
16422:C 21 Jun 00:44:47.062 * DB saved on disk
16422:C 21 Jun 00:44:47.063 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:44:47.154 * Background saving terminated with success
227:M 21 Jun 00:49:48.084 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:49:48.084 * Background saving started by pid 16761
16761:C 21 Jun 00:49:48.093 * DB saved on disk
16761:C 21 Jun 00:49:48.094 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:49:48.186 * Background saving terminated with success
227:M 21 Jun 00:54:49.093 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:54:49.093 * Background saving started by pid 17097
17097:C 21 Jun 00:54:49.103 * DB saved on disk
17097:C 21 Jun 00:54:49.103 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:54:49.194 * Background saving terminated with success
227:M 21 Jun 00:59:50.008 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 00:59:50.008 * Background saving started by pid 17430
17430:C 21 Jun 00:59:50.017 * DB saved on disk
17430:C 21 Jun 00:59:50.017 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 00:59:50.108 * Background saving terminated with success
227:M 21 Jun 01:04:51.003 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:04:51.003 * Background saving started by pid 17769
17769:C 21 Jun 01:04:51.024 * DB saved on disk
17769:C 21 Jun 01:04:51.024 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:04:51.104 * Background saving terminated with success
227:M 21 Jun 01:09:52.021 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:09:52.021 * Background saving started by pid 18103
18103:C 21 Jun 01:09:52.030 * DB saved on disk
18103:C 21 Jun 01:09:52.030 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:09:52.122 * Background saving terminated with success
227:M 21 Jun 01:14:53.010 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:14:53.010 * Background saving started by pid 18442
18442:C 21 Jun 01:14:53.026 * DB saved on disk
18442:C 21 Jun 01:14:53.026 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:14:53.110 * Background saving terminated with success
227:M 21 Jun 01:19:54.098 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:19:54.099 * Background saving started by pid 18779
18779:C 21 Jun 01:19:54.107 * DB saved on disk
18779:C 21 Jun 01:19:54.108 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:19:54.199 * Background saving terminated with success
227:M 21 Jun 01:24:55.014 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:24:55.014 * Background saving started by pid 19113
19113:C 21 Jun 01:24:55.023 * DB saved on disk
19113:C 21 Jun 01:24:55.023 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:24:55.114 * Background saving terminated with success
227:M 21 Jun 01:29:56.038 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:29:56.038 * Background saving started by pid 19448
19448:C 21 Jun 01:29:56.048 * DB saved on disk
19448:C 21 Jun 01:29:56.048 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:29:56.139 * Background saving terminated with success
227:M 21 Jun 01:34:57.033 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:34:57.033 * Background saving started by pid 19790
19790:C 21 Jun 01:34:57.042 * DB saved on disk
19790:C 21 Jun 01:34:57.042 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:34:57.133 * Background saving terminated with success
227:M 21 Jun 01:39:58.030 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:39:58.031 * Background saving started by pid 20119
20119:C 21 Jun 01:39:58.039 * DB saved on disk
20119:C 21 Jun 01:39:58.040 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:39:58.132 * Background saving terminated with success
227:M 21 Jun 01:44:59.024 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:44:59.024 * Background saving started by pid 20463
20463:C 21 Jun 01:44:59.033 * DB saved on disk
20463:C 21 Jun 01:44:59.034 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:44:59.124 * Background saving terminated with success
227:M 21 Jun 01:50:00.037 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:50:00.038 * Background saving started by pid 20806
20806:C 21 Jun 01:50:00.047 * DB saved on disk
20806:C 21 Jun 01:50:00.047 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:50:00.138 * Background saving terminated with success
227:M 21 Jun 01:55:01.052 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 01:55:01.052 * Background saving started by pid 21139
21139:C 21 Jun 01:55:01.063 * DB saved on disk
21139:C 21 Jun 01:55:01.064 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 01:55:01.152 * Background saving terminated with success
227:M 21 Jun 02:00:02.098 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:00:02.098 * Background saving started by pid 21475
21475:C 21 Jun 02:00:02.108 * DB saved on disk
21475:C 21 Jun 02:00:02.108 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:00:02.198 * Background saving terminated with success
227:M 21 Jun 02:05:03.028 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:05:03.029 * Background saving started by pid 21817
21817:C 21 Jun 02:05:03.038 * DB saved on disk
21817:C 21 Jun 02:05:03.039 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:05:03.129 * Background saving terminated with success
227:M 21 Jun 02:10:04.042 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:10:04.043 * Background saving started by pid 22145
22145:C 21 Jun 02:10:04.052 * DB saved on disk
22145:C 21 Jun 02:10:04.052 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:10:04.143 * Background saving terminated with success
227:M 21 Jun 02:15:05.064 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:15:05.064 * Background saving started by pid 22483
22483:C 21 Jun 02:15:05.074 * DB saved on disk
22483:C 21 Jun 02:15:05.074 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:15:05.165 * Background saving terminated with success
227:M 21 Jun 02:20:06.055 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:20:06.055 * Background saving started by pid 22819
22819:C 21 Jun 02:20:06.064 * DB saved on disk
22819:C 21 Jun 02:20:06.064 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:20:06.155 * Background saving terminated with success
227:M 21 Jun 02:25:07.050 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:25:07.050 * Background saving started by pid 23154
23154:C 21 Jun 02:25:07.059 * DB saved on disk
23154:C 21 Jun 02:25:07.060 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:25:07.150 * Background saving terminated with success
227:M 21 Jun 02:30:08.052 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:30:08.053 * Background saving started by pid 23488
23488:C 21 Jun 02:30:08.062 * DB saved on disk
23488:C 21 Jun 02:30:08.062 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:30:08.153 * Background saving terminated with success
227:M 21 Jun 02:35:09.059 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:35:09.059 * Background saving started by pid 23831
23831:C 21 Jun 02:35:09.068 * DB saved on disk
23831:C 21 Jun 02:35:09.069 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:35:09.159 * Background saving terminated with success
227:M 21 Jun 02:40:10.076 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:40:10.076 * Background saving started by pid 24160
24160:C 21 Jun 02:40:10.085 * DB saved on disk
24160:C 21 Jun 02:40:10.085 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:40:10.176 * Background saving terminated with success
227:M 21 Jun 02:45:11.089 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:45:11.089 * Background saving started by pid 24499
24499:C 21 Jun 02:45:11.098 * DB saved on disk
24499:C 21 Jun 02:45:11.099 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:45:11.189 * Background saving terminated with success
227:M 21 Jun 02:50:12.090 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:50:12.090 * Background saving started by pid 24835
24835:C 21 Jun 02:50:12.100 * DB saved on disk
24835:C 21 Jun 02:50:12.100 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:50:12.190 * Background saving terminated with success
227:M 21 Jun 02:55:13.086 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 02:55:13.087 * Background saving started by pid 25170
25170:C 21 Jun 02:55:13.096 * DB saved on disk
25170:C 21 Jun 02:55:13.097 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 02:55:13.187 * Background saving terminated with success
227:M 21 Jun 03:00:14.095 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:00:14.095 * Background saving started by pid 25499
25499:C 21 Jun 03:00:14.105 * DB saved on disk
25499:C 21 Jun 03:00:14.106 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:00:14.196 * Background saving terminated with success
227:M 21 Jun 03:05:15.019 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:05:15.019 * Background saving started by pid 25839
25839:C 21 Jun 03:05:15.028 * DB saved on disk
25839:C 21 Jun 03:05:15.029 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:05:15.120 * Background saving terminated with success
227:M 21 Jun 03:10:16.020 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:10:16.020 * Background saving started by pid 26171
26171:C 21 Jun 03:10:16.029 * DB saved on disk
26171:C 21 Jun 03:10:16.029 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:10:16.120 * Background saving terminated with success
227:M 21 Jun 03:15:17.038 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:15:17.038 * Background saving started by pid 26507
26507:C 21 Jun 03:15:17.047 * DB saved on disk
26507:C 21 Jun 03:15:17.048 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:15:17.138 * Background saving terminated with success
227:M 21 Jun 03:20:18.034 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:20:18.035 * Background saving started by pid 26845
26845:C 21 Jun 03:20:18.047 * DB saved on disk
26845:C 21 Jun 03:20:18.047 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:20:18.135 * Background saving terminated with success
227:M 21 Jun 03:25:19.020 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:25:19.020 * Background saving started by pid 27179
27179:C 21 Jun 03:25:19.029 * DB saved on disk
27179:C 21 Jun 03:25:19.030 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:25:19.121 * Background saving terminated with success
227:M 21 Jun 03:30:20.018 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:30:20.018 * Background saving started by pid 27510
27510:C 21 Jun 03:30:20.027 * DB saved on disk
27510:C 21 Jun 03:30:20.027 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:30:20.118 * Background saving terminated with success
227:M 21 Jun 03:35:21.022 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:35:21.022 * Background saving started by pid 27852
27852:C 21 Jun 03:35:21.031 * DB saved on disk
27852:C 21 Jun 03:35:21.032 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:35:21.123 * Background saving terminated with success
227:M 21 Jun 03:40:22.026 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:40:22.027 * Background saving started by pid 28182
28182:C 21 Jun 03:40:22.036 * DB saved on disk
28182:C 21 Jun 03:40:22.036 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:40:22.127 * Background saving terminated with success
227:M 21 Jun 03:45:23.031 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:45:23.032 * Background saving started by pid 28519
28519:C 21 Jun 03:45:23.040 * DB saved on disk
28519:C 21 Jun 03:45:23.041 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:45:23.132 * Background saving terminated with success
227:M 21 Jun 03:50:24.020 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:50:24.020 * Background saving started by pid 28855
28855:C 21 Jun 03:50:24.029 * DB saved on disk
28855:C 21 Jun 03:50:24.030 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:50:24.120 * Background saving terminated with success
227:M 21 Jun 03:55:25.029 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 03:55:25.029 * Background saving started by pid 29193
29193:C 21 Jun 03:55:25.044 * DB saved on disk
29193:C 21 Jun 03:55:25.044 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 03:55:25.129 * Background saving terminated with success
227:M 21 Jun 04:00:26.039 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:00:26.039 * Background saving started by pid 29527
29527:C 21 Jun 04:00:26.048 * DB saved on disk
29527:C 21 Jun 04:00:26.048 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:00:26.139 * Background saving terminated with success
227:M 21 Jun 04:05:27.056 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:05:27.056 * Background saving started by pid 29865
29865:C 21 Jun 04:05:27.065 * DB saved on disk
29865:C 21 Jun 04:05:27.065 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:05:27.157 * Background saving terminated with success
227:M 21 Jun 04:10:28.072 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:10:28.072 * Background saving started by pid 30197
30197:C 21 Jun 04:10:28.081 * DB saved on disk
30197:C 21 Jun 04:10:28.082 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:10:28.172 * Background saving terminated with success
227:M 21 Jun 04:15:29.084 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:15:29.085 * Background saving started by pid 30535
30535:C 21 Jun 04:15:29.094 * DB saved on disk
30535:C 21 Jun 04:15:29.094 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:15:29.185 * Background saving terminated with success
227:M 21 Jun 04:20:30.078 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:20:30.078 * Background saving started by pid 30890
30890:C 21 Jun 04:20:30.087 * DB saved on disk
30890:C 21 Jun 04:20:30.088 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:20:30.178 * Background saving terminated with success
227:M 21 Jun 04:25:31.012 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:25:31.012 * Background saving started by pid 31230
31230:C 21 Jun 04:25:31.022 * DB saved on disk
31230:C 21 Jun 04:25:31.022 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:25:31.112 * Background saving terminated with success
227:M 21 Jun 04:30:32.002 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:30:32.002 * Background saving started by pid 31569
31569:C 21 Jun 04:30:32.015 * DB saved on disk
31569:C 21 Jun 04:30:32.015 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:30:32.103 * Background saving terminated with success
227:M 21 Jun 04:35:33.098 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:35:33.098 * Background saving started by pid 31908
31908:C 21 Jun 04:35:33.107 * DB saved on disk
31908:C 21 Jun 04:35:33.108 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:35:33.198 * Background saving terminated with success
227:M 21 Jun 04:40:34.003 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:40:34.003 * Background saving started by pid 32239
32239:C 21 Jun 04:40:34.016 * DB saved on disk
32239:C 21 Jun 04:40:34.016 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:40:34.104 * Background saving terminated with success
227:M 21 Jun 04:45:35.094 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:45:35.094 * Background saving started by pid 32581
32581:C 21 Jun 04:45:35.103 * DB saved on disk
32581:C 21 Jun 04:45:35.104 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:45:35.195 * Background saving terminated with success
227:M 21 Jun 04:50:36.093 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:50:36.093 * Background saving started by pid 463
463:C 21 Jun 04:50:36.102 * DB saved on disk
463:C 21 Jun 04:50:36.103 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:50:36.193 * Background saving terminated with success
227:M 21 Jun 04:55:37.007 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 04:55:37.007 * Background saving started by pid 810
810:C 21 Jun 04:55:37.016 * DB saved on disk
810:C 21 Jun 04:55:37.016 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 04:55:37.107 * Background saving terminated with success
227:M 21 Jun 05:00:38.042 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 05:00:38.042 * Background saving started by pid 1143
1143:C 21 Jun 05:00:38.051 * DB saved on disk
1143:C 21 Jun 05:00:38.052 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 05:00:38.142 * Background saving terminated with success
227:M 21 Jun 05:05:39.034 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 05:05:39.034 * Background saving started by pid 1482
1482:C 21 Jun 05:05:39.049 * DB saved on disk
1482:C 21 Jun 05:05:39.050 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 05:05:39.135 * Background saving terminated with success
227:M 21 Jun 05:10:40.064 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 05:10:40.064 * Background saving started by pid 1813
1813:C 21 Jun 05:10:40.073 * DB saved on disk
1813:C 21 Jun 05:10:40.073 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 05:10:40.164 * Background saving terminated with success
227:M 21 Jun 05:15:41.061 * 10 changes in 300 seconds. Saving...
227:M 21 Jun 05:15:41.061 * Background saving started by pid 2154
2154:C 21 Jun 05:15:41.070 * DB saved on disk
2154:C 21 Jun 05:15:41.070 * RDB: 0 MB of memory used by copy-on-write
227:M 21 Jun 05:15:41.161 * Background saving terminated with success
(Felix Freiberger) #15
Sorry for being unclear – I wanted you to visit the URL /logs on your site, i.e. https://<your domain>/logs. Alternatively, in the admin area, click Logs, then Error Logs.
(Rohit Manglik) #16
Here is the output:
(Felix Freiberger) #17
Hm, that looks unrelated, so I’m out of ideas for now. Try with a different mail provider, in case your provider has a weird spam filter?
(Rohit Manglik) #18
Hi @fefrei,
Can you please look into Upgrade, force SSL, Emails not working - Discourse - Bitnami Community
I switched to the Official procedure but still facing the issue. Can you please provide me the version of this code for a normal Discourse installation?
Thanks a lot in advance.
Regards
Rohit
(Felix Freiberger) #19
There is no need to do this in the Docker image - Sidekiq will already be working on all these queues. Sorry, but I’m currently out of ideas.
(Rohit Manglik) #20
@codinghorror @sam Can you please guide. I am completely stuck now. if required, I can send you my server details - I don’t have any important data over there.
