I have version v1.7.0.beta2, and I tried to upgrade it but it doesn’t work.
How can I upgrade it?
Or at least, upgrade to a specific commit, so I go step by step.
Is that possible?
Is that possible?
Can you define “doesn’t work”?
What error are you getting? What issue are you running into?
It says it can’t remove postgres 9.5 and some dependencies.
After that, I can’t even restart the app, so I can’t use admin.
root@ip-172-30-0-241:/var/discourse# ./launcher rebuild app
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 10 app
app
cd /pups && git pull && /pups/bin/pups --stdin
Already up-to-date.
I, [2017-06-09T15:41:19.421365 #13] INFO -- : Loading --stdin
I, [2017-06-09T15:41:19.425902 #13] INFO -- : > apt-get remove -y postgresql-9.5 postgresql-client-9.5 postgresql-contrib-9.5
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "es_ES.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
E: Sub-process /usr/bin/dpkg returned an error code (1)
I, [2017-06-09T15:41:21.951351 #13] INFO -- : Reading package lists...
Building dependency tree...
Reading state information...
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 3 to remove and 0 not upgraded.
After this operation, 26.1 MB disk space will be freed.
(Reading database ... 34469 files and directories currently installed.)
Removing postgresql-contrib-9.5 (9.5.7-1.pgdg16.04+1) ...
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/9.5/man/man1/postmaster.1.gz because link group postmaster.1.gz is broken
update-alternatives: error: error creating symbolic link '/usr/share/man/man1/postmaster.1.gz.dpkg-tmp': No such file or directory
dpkg: error processing package postgresql-contrib-9.5 (--remove):
subprocess installed pre-removal script returned error exit status 2
dpkg: postgresql-9.5: dependency problems, but removing anyway as you requested:
postgresql-contrib-9.5 depends on postgresql-9.5 (= 9.5.7-1.pgdg16.04+1).
Removing postgresql-9.5 (9.5.7-1.pgdg16.04+1) ...
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of stop.
Removing postgresql-client-9.5 (9.5.7-1.pgdg16.04+1) ...
Processing triggers for postgresql-common (182.pgdg16.04+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
Errors were encountered while processing:
FAILED
Pups::ExecError: apt-get remove -y postgresql-9.5 postgresql-client-9.5 postgresql-contrib-9.5 failed with return #<Process::Status: pid 15 exit 100>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params "apt-get remove -y postgresql-9.5 postgresql-client-9.5 postgresql-contrib-9.5"
d749bb7c18042118b00c527544e31139ccf27b65e49b9a2c1998409e248ba937
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
I’m trying everything.
I had upgraded and when I try to restore my backup, I get this error.
Bundled gems are installed into ./vendor/bundle.
I, [2017-06-16T14:01:09.968006 #13] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
2017-06-16 14:01:15.455 UTC [13337] discourse@discourse ERROR: permission denied for sequence site_settings_id_seq
2017-06-16 14:01:15.455 UTC [13337] discourse@discourse STATEMENT: INSERT INTO "site_settings" ("name", "value", "data_type", "created_at", "updated_at") VALUES ('send_welcome_message', 'f', 5, '2017-06-16 14:01:15.454605', '2017-06-16 14:01:15.454605') RETURNING "id"
rake aborted!
