Upgrade gives name error
(Carlo Kok) #1
Getting this since yesterday when trying to upgrade (simple docker):
rake aborted!
NameError: wrong constant name warning
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/inflector/methods.rb:261:in `const_get'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/inflector/methods.rb:261:in `block in constantize'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/inflector/methods.rb:259:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/inflector/methods.rb:259:in `inject'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/inflector/methods.rb:259:in `constantize'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/core_ext/string/inflections.rb:66:in `constantize'
/var/www/discourse/lib/plugin/instance.rb:123:in `rescue in add_model_callback'
/var/www/discourse/lib/plugin/instance.rb:123:in `add_model_callback'
/var/www/discourse/plugins/discourse-staff-notes/plugin.rb:154:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:209:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:207:in `each'
/var/www/discourse/lib/plugin/instance.rb:207:in `notify_after_initialize'
/var/www/discourse/config/application.rb:209:in `block (2 levels) in <class:Application>'
/var/www/discourse/config/application.rb:209:in `each'
/var/www/discourse/config/application.rb:209:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/lazy_load_hooks.rb:36:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/lazy_load_hooks.rb:45:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/lazy_load_hooks.rb:44:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/lazy_load_hooks.rb:44:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/application/finisher.rb:62:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/initializable.rb:30:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/initializable.rb:30:in `run'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/initializable.rb:55:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/initializable.rb:54:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/application.rb:352:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/config/environment.rb:5:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/dependencies.rb:274:in `require'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/dependencies.rb:274:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.8/lib/active_support/dependencies.rb:240:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/application.rb:328:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.8/lib/rails/application.rb:457:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-11.3.0/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
NameError: uninitialized constant Warning
Tasks: TOP => multisite:migrate => environment
(Régis Hanol) #2
What branch are you following?
(Carlo Kok) #3
I’m following tests-passed
(Sam Saffron) #4
Try a rebuild, try removing staff notes plugin
(Carlo Kok) #5
thanks! that solved it.
(Sam Saffron) #6
which of the two thats solved it ? :wink:
(Carlo Kok) #7
Actually upgraded staff-notes did it. Turns out there was an update that I needed to do there first (I usually upgrade discourse first, then the plugins)
