Upgrade to Beta8 deletes all icons
(Sebastian) #1
Just upgraded to beta8 and now all images are gone (small logo, big logo, favicons, all these things)…
#2
I do not make a new topic, after updating the latest version I have a little problem:
logo-d
When I use the scroll in the topic, the discourse logo appears.
mini-bug
(Jay Pfaffman) #3
run /wizard to replace them.
(Sebastian) #4
I know how to replace them, even without the wizard. The point is they were there and the update removed them, which is not exactly what should be happening… :slight_smile:
(Chris Croome) #5
I have had the same thing happen (icons vanish and need to be uploaded again) on a couple of servers.
(Joshua Rosenfeld) #6
What version did you upgrade from?
(Sebastian) #7
the one before, beta7, I always upgrade when I get that email that an upgrade is available, since it is not yet a very active forum and I can afford to “break stuff” :wink:
(Joshua Rosenfeld) #8
Interesting. If you were jumping versions, perhaps from an early 2.2.0 beta before we changed site setting image uploads, I’d be less surprised. Perhaps @sam or @tgxworld have thoughts?
(Chris Croome) #10
A development server that had the default icons that Discourse comes with, that I have just upgraded from v2.2.0.beta7 +13 to v2.2.0.beta8 +10 and the icons have gone, see:
This is a screenshot of the settings.
(Alan Tan) #11
Can you provide me with the output of the following commands?
./launcher enter app
rails c
SiteSetting.where(name: "logo_url").first
(Alan Tan) #12
This is a new change. See FIX: Show title as home logo if title has been set and logo is blank. · discourse/discourse@2956c52 · GitHub
#13
Hei @tgxworld
Do you have any idea why the discourse logo appears, if the settings is the default? I have posted a screenshot on the top.
(Alan Tan) #14
The default logo does not appear at the moment but we do have a pending fix in the pipeline.
(Chris Croome) #15
Here you go:
rails c
[1] pry(main)> SiteSetting.where(name: "logo_url").first
=> nil
(Alan Tan) #16
It doesn’t look like logo_url was configured in the first place. Which other icons did you notice go missing?
(Chris Croome) #17
No logo configuration had been done, the site did have the default Discourse logo before the last upgrade, now it doesn’t, look for yourself:
This is a months old site that was setup to do some development with, but that development never happened so I have simply been upgrading it when prompted.
(Alan Tan) #18
O this is a recent change in FIX: Show title as home logo if title has been set and logo is blank. · discourse/discourse@2956c52 · GitHub.
(Chris Croome) #19
There is no web-based upgrade available, are you suggesting that I rebuild the app on the command line? Or are you saying that the behavior I have reported is to be expected?
(Alan Tan) #20
The behavior is expected.
(Chris Croome) #21
Thanks for the clarification, I’ll now upgrade some other servers and re-add the images that will vanish as a result of the upgrade, perhaps it it might be possible to make it clearer that people should expect to have to re-add the site logos after this upgrade — I probably won’t be the last person to suspect that this is a bug rather than a feature.
