Upgrade using docker manager fail to create extension "fuzzystrmatch"
(Tuan Anh Tran) #1
2014-07-11 20:55:02 UTC ERROR:  permission denied to create extension "fuzzystrmatch"
This failed when I upgrade to latest master discourse (02158e5) using docker manager web ui. I have to ssh into the container and create the extension myself.
(Bill Ayakatubby) #2
See also:
https://meta.discourse.org/t/error-while-upgrading-discourse-board-now-not-functioning/17473?source_topic_id=17479
(Jeff Atwood) #3
Related to
http://www.postgresql.org/docs/9.1/static/fuzzystrmatch.html
and
Looks like the fuzzystrmatch stuff is not present in the DB for some reason, and adding it requires elevation?
(Kane York) #4
Yes - it looks like everybody will need to rebuild their Docker containers.
(Jeff Atwood) #5
OK @zogstrip is pulling this commit and will submit it in a different form that doesn’t require adding new DB extensions. Sorry about that. Should be better now.
(Jeff Atwood) #6
