Upgrading from Discourse 0.9.9.5
(Jessp01) #1
Hello all,
I have installed this instance using the now deprecated method listed here:
https://github.com/discourse/discourse/blob/master/docs/INSTALL-ubuntu.md
I understand the current recommended install is via Docker which I am fine with.
However, looking here:
It says: Both the new and old Discourses MUST BE ON THE EXACT SAME VERSION to ensure proper backup/export.
How do I upgrade the existing instance to latest or, is there another easier option?
I am fine with any solution so long as there is no data loss.
Thanks,
#2
Someone chime in if I’m in the wrong here, but it seems you would need to upgrade your current install first, then migrate the data to the new server with a docker install.
This is towards the bottom of the link in your OP
##UPDATING DISCOURSE
# Run these commands as the discourse user
bluepill stop
bluepill quit
# Back up your install
DATESTAMP=$(TZ=UTC date +%F-%T)
pg_dump --no-owner --clean discourse_prod | gzip -c > ~/discourse-db-$DATESTAMP.sql.gz
tar cfz ~/discourse-dir-$DATESTAMP.tar.gz -C /var/www discourse
# get the latest Discourse code
cd /var/www/discourse
git checkout master
git pull
git fetch --tags
# To run on the latest numbered release instead of bleeding-edge:
#git checkout latest-release
# Follow the section below titled:
# "Check sample configuration files for new settings"
bundle install --without test --deployment
RUBY_GC_MALLOC_LIMIT=90000000 RAILS_ENV=production bundle exec rake db:migrate
RUBY_GC_MALLOC_LIMIT=90000000 RAILS_ENV=production bundle exec rake assets:precompile
# restart bluepill
crontab -l
# Here, run the command to start bluepill.
# Get it from the crontab output above.
(Jeff Atwood) #3
Already covered at
(Jeff Atwood) #4
