Upgrading from v1.5 to v1.6
#1
I’m unable to upgrade my discourse. When I try from the website I get this message.
Upgrades via the web UI are disabled until you run the latest image.
To do so log in to your server using SSH and run:
cd /var/discourse
git pull
./launcher rebuild app
When I try that I get this error message.
ERROR: Docker version 1.2.0 not supported, please upgrade to at least 1.8.0, or recommended 1.8.0
(eriko) #2
You are running a very very old version of docker. It will need to be updated first as the current docker image requires features provided by newer versions of docker.
#3
How do I upgrade the docker?
(Jeff Atwood) #4
apt-get update
apt-get upgrade lxc-docker
That should get you to 1.9 fairly reliably. Do that first. To clean up space, I also recommend
cd /var/discourse
./launcher cleanup
apt-get autoclean
apt-get autoremove
#5
Ok, I went through all these steps but when I finally ./launcher rebuild app my discourse is now completely unresponsive. I get a can’t connect to server error when I try to open from Safari.
(Jeff Atwood) #6
Did you get errors? If you have any non default plugins, remove them.
#7
Thanks for all your help. I’m not using any plugins but I ran the command again and it works now.
The first time I ran the command it ended with this message.
UPGRADE OF POSTGRES COMPLETE
Old 9.3 database is stored at /shared/postgres_data_old
Please run ./launcher bootstrap again
I missed that but the second time I ran ./launcher rebuild app it worked.
(Jeff Atwood) #8
Excellent, good work! You did it! :tada:
(Sam Saffron) #9
Thanks I corrected the text so it is now:
Please run ./launcher rebuild again
(Ionuț Staicu) #10
I already updated few days ago, but if I remember well, this didn’t worked back then either:
$ apt-get upgrade lxc-docker
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
Package lxc-docker is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'lxc-docker' has no installation candidate
I managed to update by removing the old version and reinstall the new one.
$ apt-get purge lxc-docker*
$ curl -fsSL https://get.docker.com/ | sh
Last command took forever to complete. At one point I started to worry, but after ~20 mins it was up & running.
I’m not saying this is the way of upgrading, but this was the way worked for me.
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.4 LTS
Release:        14.04
Codename:       trusty
